ROLL CAGE --- A PILLAR POST QUESTION ???? #865186
11/27/10 11:57 PM
11/27/10 11:57 PM
alabama
mopars rule Offline OP
mopar addict
mopar addict
alabama
I am ready to put in my A pillar posts for my rolll cage. I see a lot of them welded to the 6 x 6 plate welded to the floor pan. What other ways have some of you mounted yours to the floor. Looking for a little more solid way to do it. Pictures would be helpful also.
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: mopars rule] #865187
11/28/10 12:10 AM
11/28/10 12:10 AM
Q
Quicktree Offline
Quicktree  Offline
Q
if youre using a factory floor pan not a lot you can do unless you want to add floor bars either under it or on top.
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: Quicktree] #865188
11/28/10 12:18 AM
11/28/10 12:18 AM
I would sugest that you keep the bar as far forward as possable so you notch the front of the dash
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: ] #865189
11/28/10 01:03 AM
11/28/10 01:03 AM
alabama
mopar addict
mopar addict
alabama
I have thought about possibly welding a piece of tubing from the trans crossmember to the floor support about 7" forward of it. I would like to come up through the floor pan with it. Would this be worth doing or a waste of time?
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: mopars rule] #865190
11/28/10 01:08 AM
11/28/10 01:08 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
not totally sure what you mean here. Would it be diagonal under your feet and legs, going 7" further forward and outward to where to a pillar bar comes down?
-Kenny
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: StrokerAspen] #865191
11/28/10 01:13 AM
11/28/10 01:13 AM
alabama
mopar addict
mopar addict
alabama
Just going forward to another floor support. The tubing would be against the rocker panel and welded to it also.
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: StrokerAspen] #865192
11/28/10 01:14 AM
11/28/10 01:14 AM
I this would be a waste of time and effort.
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: ] #865193
11/28/10 01:24 AM
11/28/10 01:24 AM
alabama
mopar addict
mopar addict
alabama
Looks like I might have to just do it the old way and weld the plates to the floor. Unless someone comes up with an idea.
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: mopars rule] #865194
11/28/10 02:29 AM
11/28/10 02:29 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I put put a piece of 2X3 tubing from the unibody to the rocker then weld the a pillar bar to it. My main hoop is done that way also. My car is 25.5 and its legal.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: bigtimeauto] #865195
11/28/10 02:31 AM
11/28/10 02:31 AM
alabama
mopar addict
mopar addict
alabama
Any chance you have a picture of that handywork?
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: bigtimeauto] #865196
11/28/10 02:31 AM
11/28/10 02:31 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
THIS ^^^^ if you plan on going faster than 8.50 it will need it anyways
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: mopars rule] #865197
11/28/10 02:33 AM
11/28/10 02:33 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I have a bottom pic of my car but the lift is in the way. if you look real careful you can see the rear ones.
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: bigtimeauto] #865198
11/28/10 02:36 AM
11/28/10 02:36 AM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
thats how i done my Dart its 25.5 now
just slot the floor pan by the rocker to slide the 2x3 thru the floor angled from the frame rail to the rocker (plate the rocker)
there might be pics on my website under customer cars of when i did the Dart for Brian
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: bigtimeauto] #865199
11/28/10 02:42 AM
11/28/10 02:42 AM
alabama
mopar addict
mopar addict
alabama
I can just barely see the one on the passenger side right above the yellow lift pad. Looks like your bars go a little farther forward than mine. Mine will stop just forward of the trans crossmember. By the way, nice ride.
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: mopars rule] #865200
11/28/10 02:45 AM
11/28/10 02:45 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Thanks! My bars go thru the dash and stick right with the pillar so they can't be seen fromoutside
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: bigtimeauto] #865201
11/28/10 03:00 AM
11/28/10 03:00 AM
alabama
mopar addict
mopar addict
alabama
Thanks for the info fellas. I just went to the garage and looked at my car and I see exactly what you are talking about. I will be doing exactly that. That's the knowledge I was looking for. Thanks.
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: mopars rule] #865202
11/28/10 11:07 AM
11/28/10 11:07 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I removed the front brace between the rocker and frame rail for access. I also found it easier to remove a section of the floor for access and reinstall it afterward. I plated the rocker before installing 2"x3" tube.
Doug
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: dvw] #865203
11/28/10 11:09 AM
11/28/10 11:09 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
another pic
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: dvw] #865204
11/28/10 11:19 AM
11/28/10 11:19 AM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
I did the same thing at the rear as the front, I like the 2x3 tube method better then the plate meathod. If your floor pan isn't super clean and rust free then the 6x6 plate would probably punch right through it if you put your car on it's lid. I also agree with what was said abouve about putting the a pilar bars through the dash, mine are in front and they are a P.I.T.A. to get in and out of the car. I'm changing that since I'm 25.5'ing my car. here is a pic of the rear on my junk.
Steve
Photobucket sucks
Re: ROLL CAGE --- A PILLAR POST QUESTION ???? [Re: 72chrgrally] #865205
11/28/10 05:18 PM
11/28/10 05:18 PM
alabama
mopar addict
mopar addict
alabama
Excellent pictures. Thanks.
