Questions about Rotisserie Mounting 69 Roadrunner:
#863575
11/25/10 07:01 PM
11/25/10 07:01 PM
Posts: 712 California
BigDaddy440
California
It's Thanksgiving Day so I thought I'd try to get this bird mounted on the rotisserie this morning! Well, at least get it closer to being mounted. QUESTIONS: Most Rotisseries attach to the car by sliding square / rectangular steel arms into the box shape of the frame both front and back. Is this also true on a 69 b body? Here's the front of my 69 Roadrunner: ![](http://i51.tinypic.com/aw99qa.jpg) I know I need to remove the radiator support and fenders, but I'm not exactly sure how to go about this. I see the bolts that need to be removed but there's more to it than just removing bolts, at least I think so. It appears that the radiator support and fenders are either pressed or tack welded together, is this correct? Assuming I need to remove the radiator support and the fenders to mount the car on the rotisserie, what is the best way to go about removing these pieces without damaging the car? Thanks for any advice / help. -dan
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
Re: Questions about Rotisserie Mounting 69 Roadrunner:
[Re: Neil]
#863579
11/25/10 07:41 PM
11/25/10 07:41 PM
Posts: 2,592 None
71rm23
None
Attach it to the car body using the same holes the bumper brackets mount to.
For the rear
[Re: 71rm23]
#863580
11/25/10 08:03 PM
11/25/10 08:03 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
For the rear
TOO!
[Re: LimeliteAero]
#863581
11/25/10 09:02 PM
11/25/10 09:02 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Sorry, I didn't take any pics of my car on my rotiserie (I built mine and all the attachments myself), but
- 1) as the others have said; you do NOT remove the inner fenders/front frame rails, rad support!
- 2) use the factory bolt holes for the bumper brackets front AND rear!
Hopefully the rotiserie you bought wasn't just for chevies and it has all the pces to extend to 18' long. If you need to build adaptors to attach the arms to your car, it isn't that hard.
Good luck,
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: RodStRace]
#863583
11/25/10 10:10 PM
11/25/10 10:10 PM
Posts: 287 Greenville, N.C.
BarrsRestoration
Greenville, N.C.
Lots of B-bodies on rotisseries on the Clark Classic link. Like mentioned by others, use the bumper mount locatiions. On the rear I use a 1/4" thick spacer plate between the mount and the car, just above the raised rib in the reinforcing plate of the rear mount location. Steve www.clarkclassic.com
[Re: 68jim]
#863586
11/26/10 10:21 PM
11/26/10 10:21 PM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
Dan, here are a few photos of my Road Runner rotisserie brackets. Once you remove the front fenders, you'll see the headlight bucket area stays with them. By the way, your car looks really familiar. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: Dave Watt]
#863590
11/27/10 03:03 AM
11/27/10 03:03 AM
BigDaddy440
California
Wow, thank you all, those pictures are great. The pics give me confidence that I'm securing the car correctly!
So I think I have it all figured out. I made a template out of cardboard and I had a shop fab up some rear brackets so fit my rotisserie. They came out really nice, I'll post some pictures tomorrow.
-dan
