Measuring deck height? #863306
11/25/10 05:54 AM
11/25/10 05:54 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
When measuring deck height (center of crank to top of block), without special tools, what other kinds of measuring tools can be used? A yard stick is, of course, not very accurate, but what else can I use that won't cost me a fortune?
Re: Measuring deck height? [Re: polkat] #863307
11/25/10 06:29 AM
11/25/10 06:29 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've gotten decent results with a 12" dial caliper.... Measure the height from the deck to the crank bore, add half the bearing bore diameter & you have a good number..
Re: Measuring deck height? [Re: polkat] #863308
11/25/10 10:28 AM
11/25/10 10:28 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What will you be using the measurement for? I do what 1 Wild RT does for ordering or verifying what is needed for piston CH. It is surprisingly accurate but would not use it for determining final machining.
Re: Measuring deck height? [Re: polkat] #863309
11/25/10 10:44 AM
11/25/10 10:44 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
that is classic ... a yard stick
Re: Measuring deck height? [Re: JohnRR] #863310
11/25/10 10:54 AM
11/25/10 10:54 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Measuring deck height? [Re: polkat] #863311
11/25/10 11:00 AM
11/25/10 11:00 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
Take it to a machine shop
Re: Measuring deck height? [Re: Challenger 1] #863312
11/25/10 11:00 AM
11/25/10 11:00 AM
May I ask what your wanting to accomplish? You could use the nominal deck height ie 10.725" for a RB and use that to decide if the pistons you have in mind will work then as said mockup & see how much you need to machine to get p/v clearance/quench/cr where you want it
Re: Measuring deck height? [Re: RapidRobert] #863313
11/25/10 12:16 PM
11/25/10 12:16 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Only if you know the deck has not been cut.
Re: Measuring deck height? [Re: BSB67] #863314
11/25/10 05:00 PM
11/25/10 05:00 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Yes, the method 1 WILD RT suggested is what I have in mind. My reason for doing it is to determine if the block is square and if it has been cut. The 12" micrometer mentioned would be perfect, but I haven't been able to find one that size. I noticed that Harbor Freight has a 24" one, but it only measures in fractions or millimeters (no dial). I suppose I could convert a millimeter reading.
Re: Measuring deck height? [Re: polkat] #863315
11/25/10 05:46 PM
11/25/10 05:46 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I don't think anyone mentioned a micrometer.
Re: Measuring deck height? [Re: BSB67] #863316
11/25/10 06:16 PM
11/25/10 06:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That would work... If you have a 10-11" ball end micrometer...
Re: Measuring deck height? [Re: 1_WILD_RT] #863317
11/26/10 12:44 AM
11/26/10 12:44 AM
you can set a round rod in the bore and mike off of that then subtract the rods diameter then add 1/2 of the bore dia. As said comes down to the accuracy of your caliper type. When MP machines the decks it leaves straight machining marks whereas machine shop milling machines make circular marks. this might help you determine if yours have been cut
Re: Measuring deck height? [Re: 1_WILD_RT] #863318
11/27/10 05:04 PM
11/27/10 05:04 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I originally bought my 12" dial caliper for measuring brake drums but I've found other uses for it. It's nice to be able to check whether a deck is stock or hacked to death without hauling it to a shop and bothering someone who has better things to do.
[url=http://lmgtfy.com/?q=12"+dial+caliper]find one here[/url]
Re: Measuring deck height? [Re: 1_WILD_RT] #863319
11/29/10 01:57 AM
11/29/10 01:57 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Floyd Lippencott IV
