Re: Measuring deck height?
[Re: polkat]
#863309
11/25/10 10:44 AM
11/25/10 10:44 AM
Posts: 74,942 U.S.S.A.
JohnRR
U.S.S.A.
A yard stick is, of course, not very accurate,
that is classic ... a yard stick
[Re: JohnRR]
#863310
11/25/10 10:54 AM
11/25/10 10:54 AM
Challenger 1
Cincinnati, Ohio
[Re: Challenger 1]
#863312
11/25/10 11:00 AM
11/25/10 11:00 AM
RapidRobert
May I ask what your wanting to accomplish? You could use the nominal deck height ie 10.725" for a RB and use that to decide if the pistons you have in mind will work then as said mockup & see how much you need to machine to get p/v clearance/quench/cr where you want it
[Re: RapidRobert]
#863313
11/25/10 12:16 PM
11/25/10 12:16 PM
Posts: 4,310 Prospect, PA
BSB67
Prospect, PA
Only if you know the deck has not been cut.
[Re: BSB67]
#863316
11/25/10 06:16 PM
11/25/10 06:16 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I don't think anyone mentioned a micrometer.
That would work... If you have a 10-11" ball end micrometer...
[Re: 1_WILD_RT]
#863317
11/26/10 12:44 AM
11/26/10 12:44 AM
RapidRobert
you can set a round rod in the bore and mike off of that then subtract the rods diameter then add 1/2 of the bore dia. As said comes down to the accuracy of your caliper type. When MP machines the decks it leaves straight machining marks whereas machine shop milling machines make circular marks. this might help you determine if yours have been cut
[Re: 1_WILD_RT]
#863318
11/27/10 05:04 PM
11/27/10 05:04 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
I've gotten decent results with a 12" dial caliper.... Measure the height from the deck to the crank bore, add half the bearing bore diameter & you have a good number..
I originally bought my 12" dial caliper for measuring brake drums but I've found other uses for it. It's nice to be able to check whether a deck is stock or hacked to death without hauling it to a shop and bothering someone who has better things to do. [url=http://lmgtfy.com/?q=12"+dial+caliper]find one here[/url]
