70 Holley 4369 Question #86321
07/09/08 01:33 PM
07/09/08 01:33 PM
Los Angeles CA
ChrisD Offline OP
ChrisD  Offline OP
Los Angeles CA
What is the plug in front of the Carb connect to? Thanks
Guys.
Re: 70 Holley 4369 Question [Re: ChrisD] #86322
07/09/08 10:46 PM
07/09/08 10:46 PM
SE VA
hemibee69 Offline
hemibee69  Offline
SE VA
The wire goes to the solenoid on the distributer. "70 and some "71 big blocks had a solenoid inside the vacuum advance can. When the carb went to idle it grounded the solenoid, this retarded the timing for improved emissions. I do not have a pic of the vac advance can but it is very noticable. By the way, you do not have the bowl vent going to the manifold vacuum port do you?
JiK
1969 Orig Hemi Super Bee Post 4 spd Red on Red (Sold sadly)
1970 Cuda Drag car 500" B1/BS 8.63 @ 155 mph
1970 Challenger SE 383 4 bbl A/C PB PS Leather
1971 Orig 440+6 Cuda 4 spd Shaker In-Violet
Re: 70 Holley 4369 Question [Re: hemibee69] #86323
07/10/08 09:57 AM
07/10/08 09:57 AM
Central,AR
hemi_tyme Offline
hemi_tyme  Offline
Central,AR
JiK
As stated above you need this vacumm advance.
Ken
