Re: Torque converter/ flex plate won't line up [Re: 340swing] #863065
11/27/10 12:06 AM
11/27/10 12:06 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's like a frikken soap opera
Don't be the exception.
Re: Torque converter/ flex plate won't line up [Re: Supercuda] #863066
11/27/10 12:37 AM
11/27/10 12:37 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
And while you're under there make sure the johnson rods and knibbling pins are still tight...Would'nt want those flying off... ...
Re: Torque converter/ flex plate won't line up [Re: Supercuda] #863067
11/27/10 02:15 AM
11/27/10 02:15 AM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
Hey POOPERCUDA As always it's great to hear from you. Those witty, well thought out comments from you make a pet rock look intelligent. Thanks for covering me BUDDY I was going to delete this thread but now that you posted I know that nobody will read this unless they want to see if you are still a tard. By the way my temps are still perfect after a year Thanks to the spring in my lower radiator hose hahahahha.
Re: Torque converter/ flex plate won't line up [Re: Boise Chall] #863068
11/27/10 09:14 AM
11/27/10 09:14 AM
scratchnfotraction Offline
dang it went down hill fast with the spring in the rad hose comment....
I thought you used a micro boiling eleminator rod in that hose
just a plane wire will cause you muffler bearing to rust then fall off..
Re: Torque converter/ flex plate won't line up [Re: scratchnfotraction] #863069
11/27/10 09:41 AM
11/27/10 09:41 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
have you marked it yet with a dab of paint?????
I always use a pint of dab ? isn't that better?
Re: Torque converter/ flex plate won't line up [Re: scratchnfotraction] #863070
11/27/10 10:55 AM
11/27/10 10:55 AM
Boise Idaho
Boise Idaho
We should stop calling it the spring in the lower radiator hose and just call it the POOPERCUDA spring hahahahhaha
Re: Torque converter/ flex plate won't line up [Re: Boise Chall] #863071
11/27/10 11:10 AM
11/27/10 11:10 AM
ouch!
Re: Torque converter/ flex plate won't line up [Re: Boise Chall] #863072
11/27/10 11:13 AM
11/27/10 11:13 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
We could call your "skills" the Boisechall (AKA d*uchebag) effect.
Why is it everything you touch turns to, well, you?
Re: Torque converter/ flex plate won't line up [Re: Supercuda] #863073
11/27/10 11:41 AM
11/27/10 11:41 AM
what you two really want to say to each other is...
G_ F_ck Y_ _r S _ lf
want to buy a vowl?
rub,jab,whack,bang,pow,back at ya!
like I said went down hill real fast
Re: Torque converter/ flex plate won't line up [Re: Supercuda] #863074
11/27/10 04:05 PM
11/27/10 04:05 PM
Boise Idaho
Boise Idaho
Is That the best you can do? WOW now I feel like I'm picking on the kid on the SHORT BUS. Maybe you should have a 2 year old write your comebacks
