CAP upper A arms????? #862901
11/24/10 09:49 PM
11/24/10 09:49 PM
Southeastern Ohio
1st_charger Offline OP
Southeastern Ohio
Anyone using the CAP Upper A arms? I bought a set for my charger and they came with a cone shaped washer / spacer and the directions don't really mention these pieces, has anyone purchaced and used these arms?
Thanks!
Re: CAP upper A arms????? [Re: 1st_charger] #862902
11/24/10 11:05 PM
11/24/10 11:05 PM
the house on the left.
cogen80 Offline
cogen80  Offline
Re: CAP upper A arms????? [Re: 1st_charger] #862903
11/24/10 11:06 PM
11/24/10 11:06 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Here we go again. Be prepared for the comments.....
Re: CAP upper A arms????? [Re: 1st_charger] #862904
11/24/10 11:39 PM
11/24/10 11:39 PM
Tidewater, VA
TMCCuda Offline
TMCCuda  Offline
Tidewater, VA
It seems to me that welding in a gusset between the tubes and ball joint for the CAP a-arms would solve some issues for them.
Maybe we should turn this over to Jaime and Adam at Mythbusters...
1970 Plymouth Barracuda 1994 Ram 1500 4x4 5.2L 2004 Ram 1500 4x4 5.7L Quad Cab
Re: CAP upper A arms????? [Re: 1st_charger] #862905
11/25/10 12:18 AM
11/25/10 12:18 AM
wv
dakster Offline
dakster  Offline
wv
Thanks!
The small tapered side goes against the heim.
Check out the pictures on Bob's Pro Fab site down near the bottom of this page.
http://www.angelfire.com/bondobob/kframe.html
Re: CAP upper A arms????? [Re: TMCCuda] #862906
11/25/10 10:06 AM
11/25/10 10:06 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I bought mine for my 68 charger last year and put about 2500 miles on them. (Mine didn't come with the stuff your asking about.) But after seeing the posts on the possible failures I welded in some gussets last week.
Re: CAP upper A arms????? [Re: rapom] #862907
11/25/10 09:09 PM
11/25/10 09:09 PM
Southeastern Ohio
Southeastern Ohio
Ok looks like they put the spacers for the heim joints in with my arms by mistake as my arms are the other type! Now all i have to do is decide if im going to use them or not!
