Re: PTC vs COAN results
[Re: KOS]
#862733
11/24/10 09:09 PM
11/24/10 09:09 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
ok first ill give some info on both verts....both are 8"the coan was built for a W2 340 it has a negative fin angle(around 100-150 degree)5500stall behind my new combo stroker indy SB. the ptc was built for a stroker BB +250 fin angle unported stator 5400stall behind the same combo as above. the coan is 10yrs old been behind several combos the ptc is bacially new.i lost almost a full 10th in 60ft with the ptc bacially 1.5ths on the top with same mph and rpm trap(same slippage).i bought the ptc because i wanted to use NOS figured it should be tighter but dissapointed.
Was the PTC built by them for your new combo? Or was "the ptc was built for a stroker BB +250 fin angle" that someone elses combo?
[Re: Troublemaker427]
#862736
11/24/10 09:18 PM
11/24/10 09:18 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Your PTC may very well be a peice of crap.
BUT, these converters are not anyway shape or form the same converter. By your own admission you ordered the converters for different combo's.
[Re: Quicksilver440]
#862738
11/24/10 09:27 PM
11/24/10 09:27 PM
KOS
they where both built for different combos.....my complaint is the slippage of the ptc.it is equal to the coan which is 11%last time i did the math.
[Re: MOPARCHAS]
#862749
11/25/10 11:18 AM
11/25/10 11:18 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
back when i had some money, i bought a PTC and a spragless from TCT at the same time. they ran exactally the same.
TC are one of those things where i wish i could buy 5 different converters and try them all. I now have one from Ultimate
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
