Anyone has a custom instrument panel for a 66 Belvedere II. I'm installing manual gauges and a few other goodies and I need a panel that will fit that area and look good. I can do the cutouts if need be but if you do them then that's kewl too. Attached is the look I want. If you need to PM then by all means do so. I need openings for a Tach,Speedo,Oil Pressure,Volt,Temp and fuel
