Valvesprings galling aluminum heads ??? #862201
11/24/10 12:49 AM
11/24/10 12:49 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Anyone have issues with valve springs galling aluminum heads without the use of a spring cup or locator?
Indy EZ heads with .600 lift roller/springs.
Wondering if the labor and expense is justified to machine for and install locators.
Re: Valvesprings galling aluminum heads ??? [Re: Stanton] #862202
11/24/10 12:58 AM
11/24/10 12:58 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Wow, didn't know anyone would even consider running the spring against an aluminum head without something under them...
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Valvesprings galling aluminum heads ??? [Re: Stanton] #862203
11/24/10 01:00 AM
11/24/10 01:00 AM
tboomer Offline
tboomer  Offline
Don't do it!! No way I would run aluminum heads without spring cups...
Re: Valvesprings galling aluminum heads ??? [Re: Stanton] #862204
11/24/10 01:01 AM
11/24/10 01:01 AM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
Valve springs need at least a shim under the valve springs to keep the spring off the aluminum head or you WILL gall the heads. Valve springs cannot run directly on the aluminum. They will rotate when the engine is operating which is when the gauling is occurring.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Valvesprings galling aluminum heads ??? [Re: Stanton] #862205
11/24/10 01:05 AM
11/24/10 01:05 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What is the problem you are having? Or is there one and you are just asking. If just asking I would not consider it.
If you are having an issue using just shims maybe you dont have enough spring and the valvesproing is "moving" around on the head due to being weak and chipping away at the seat of thehead. Seen it a couple of times on Indy heads and worn out/broken springs. Just guessing...
Re: Valvesprings galling aluminum heads ??? [Re: PUNK] #862206
11/24/10 01:14 AM
11/24/10 01:14 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
C'mon guys ... there will at least be a shim there !!!
New heads. No problem. Just asking.
Re: Valvesprings galling aluminum heads ??? [Re: Stanton] #862207
11/24/10 01:19 AM
11/24/10 01:19 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I prefer spring cups or at least the main non copper coated first spacer.
I used comps shims prior to my recent fix and didnt like how quickly the shim was wearing from everything rotating.
Now spring cups are a must.
Re: Valvesprings galling aluminum heads ??? [Re: MoparBilly] #862208
11/24/10 01:30 AM
11/24/10 01:30 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'd bet the aluminum isn't very happy.
Re: Valvesprings galling aluminum heads ??? [Re: Stanton] #862209
11/24/10 01:31 AM
11/24/10 01:31 AM
Don't run just spring shims on any aluminum head, don't ask why or how I know Use at least a spring cup or a spring locator that will not allow the spring to move more than .030 or so one side to the other and maintain at least .060 from the nearest part of aluminum that the springs can eat
Re: Valvesprings galling aluminum heads ??? [Re: Cab_Burge] #862210
11/24/10 01:37 AM
11/24/10 01:37 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Cab, not sure how BB heads are but I have to cut the pockets on every set of heads I get, id say more the 90% of the spring dia is shrouded by the head itself, with locaters ive never had a side to side issue but then again if your rec .060 thats not much and I bet im way past that.
Just for kicks I will measure next time I lash it, good point, but now just another thing to wonder about
Re: Valvesprings galling aluminum heads ??? [Re: Stanton] #862211
11/24/10 02:48 AM
11/24/10 02:48 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I dont know the question..C mon
Re: Valvesprings galling aluminum heads ??? [Re: 70blackfish] #862212
11/24/10 04:31 AM
11/24/10 04:31 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Cab is right, i've used locators but even they allowed the spring to eat into the alloy at the perimeter. these days i use & will only use cups. they support the spring better & i have no surprises when i open up my filter.
Re: Valvesprings galling aluminum heads ??? [Re: rebel] #862213
11/24/10 07:06 AM
11/24/10 07:06 AM
pa
572charger Offline
572charger  Offline
pa
spring cups are a must u must have indy heads those clowns never put spring cups on !!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Valvesprings galling aluminum heads ??? [Re: 572charger] #862214
11/24/10 09:19 AM
11/24/10 09:19 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use hardened spring locaters or hardened shims.
Re: Valvesprings galling aluminum heads ??? [Re: B G Racing] #862215
11/24/10 02:53 PM
11/24/10 02:53 PM
organ
maximum entropy Offline
organ
i prefer cups over locators. i've seen galling with locators. minor, but i am allergic to that sort of thing.
Re: Valvesprings galling aluminum heads ??? [Re: maximum entropy] #862216
11/24/10 02:57 PM
11/24/10 02:57 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Cups are great but some times the thickness prohibits their use.I personally don't like removing to much material from the spring seat if I can't get the proper spring height with locks,retainers or groove location.
Re: Valvesprings galling aluminum heads ??? [Re: B G Racing] #862217
11/24/10 03:04 PM
11/24/10 03:04 PM
organ
organ
yes! it's good to be VERY careful about removing material in that area.
Re: Valvesprings galling aluminum heads ??? [Re: maximum entropy] #862218
11/24/10 06:18 PM
11/24/10 06:18 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Cups or locators ... the thinnest I've found are all .060" thick. There is a .015 shim in there now to give the 1.9" installed height so that would mean cutting the seat .045" deeper as well as wider to 1.680 from 1.55 to fit the appropriate cup. Is there enough meat there to do that? Width looks fine but only experience can tell me if there is enough to increase the depth .045".
The alternative is just to cut the inner portion of the seat that is .661 down to .630 and use a locator instead of cup. However, the inner spring i.d. of the locator is .715 and the inner spring i.d. is actually .721. Is this still too much room for the spint to "walk"? The outer spring o.d. is 1.55 ... an exact fit to the pocket.
Re: Valvesprings galling aluminum heads ??? [Re: Stanton] #862219
11/25/10 11:15 AM
11/25/10 11:15 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Re: Valvesprings galling aluminum heads ??? [Re: Stanton] #862220
11/25/10 12:29 PM
11/25/10 12:29 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Best Machine did my indy heads......
Mopar Performance
