Re: Valvesprings galling aluminum heads ???
[Re: Stanton]
#862202
11/24/10 12:58 AM
11/24/10 12:58 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Wow, didn't know anyone would even consider running the spring against an aluminum head without something under them...
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: Stanton]
#862204
11/24/10 01:01 AM
11/24/10 01:01 AM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
Valve springs need at least a shim under the valve springs to keep the spring off the aluminum head or you WILL gall the heads. Valve springs cannot run directly on the aluminum. They will rotate when the engine is operating which is when the gauling is occurring.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: Stanton]
#862205
11/24/10 01:05 AM
11/24/10 01:05 AM
Posts: 19,696 Las Vegas
Al_Alguire
Las Vegas
What is the problem you are having? Or is there one and you are just asking. If just asking I would not consider it.
If you are having an issue using just shims maybe you dont have enough spring and the valvesproing is "moving" around on the head due to being weak and chipping away at the seat of thehead. Seen it a couple of times on Indy heads and worn out/broken springs. Just guessing...
[Re: MoparBilly]
#862208
11/24/10 01:30 AM
11/24/10 01:30 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I'd bet the aluminum isn't very happy.
[Re: B G Racing]
#862215
11/24/10 02:53 PM
11/24/10 02:53 PM
Posts: 5,080 organ
maximum entropy
organ
i prefer cups over locators. i've seen galling with locators. minor, but i am allergic to that sort of thing.
[Re: maximum entropy]
#862216
11/24/10 02:57 PM
11/24/10 02:57 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
Cups are great but some times the thickness prohibits their use.I personally don't like removing to much material from the spring seat if I can't get the proper spring height with locks,retainers or groove location.
#862218
11/24/10 06:18 PM
11/24/10 06:18 PM
Posts: 9,232 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Cups or locators ... the thinnest I've found are all .060" thick. There is a .015 shim in there now to give the 1.9" installed height so that would mean cutting the seat .045" deeper as well as wider to 1.680 from 1.55 to fit the appropriate cup. Is there enough meat there to do that? Width looks fine but only experience can tell me if there is enough to increase the depth .045".
The alternative is just to cut the inner portion of the seat that is .661 down to .630 and use a locator instead of cup. However, the inner spring i.d. of the locator is .715 and the inner spring i.d. is actually .721. Is this still too much room for the spint to "walk"? The outer spring o.d. is 1.55 ... an exact fit to the pocket.
