Re: bet you never had this problem
[Re: 62maxwgn]
#861497
11/24/10 11:00 AM
11/24/10 11:00 AM
Posts: 75,126 A Banana Republic near you.
JohnRR
The only question not ask so far that I see,is the bell housing opening concentric with the crank shaft ? If not they make offset dowel's to correct the problem.
Also what pilot bushing are you using ?
What is the engine?
[Re: kingkt]
#861499
11/24/10 12:06 PM
11/24/10 12:06 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If your'e using the stock style bushing it could be compressing when you press it into the crank. That would make for a really tight fit.
You couldn't get the transmission out of the car. That tells me the pilot pushing had a death grip on the shaft.
Forget all the other stuff for now. Measure the pilot bushing and the input shaft diameters. You will likely find the problem there.
Once you have that straightened out, fit the transmission without the clutch disc. See if the transmission is still too tight.
[Re: kingkt]
#861501
11/24/10 12:14 PM
11/24/10 12:14 PM
feets
Senior Management
Senior Management
Irving, TX
You need to take the emory cloth to the bushing. It's MUCH softer than that hardened steel shaft.
[Re: jbc426]
#861503
11/24/10 02:08 PM
11/24/10 02:08 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
Cut about 1/8 inch off the transmission input shaft where it goes into the pilot. It is bottoming out in the crankshaft and binding up.
Bingo! I'll take the bet that this is what it is. Mine did the same thing. You can easily test if this is it by loosening the 4 trans to bellhousing bolts and try shifting it when it's running then. I had to grind off about 1/2 of an inch from the input shaft to get clearance. My crank just wasn't drilled deep enough, or the scatter shield was shorter from block to trans.
It's a quick & simple test. Loosen the four transmission bolts so there's about 1/3 of an inch gap between the trans and the bell housing, start it and and try shifting it into gear. I'll bet you it goes right into gear.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: 440fied]
#861510
11/26/10 10:25 AM
11/26/10 10:25 AM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
Yep, it fits in the crank in front of the hole where the bronze pilot bushing goes. Just take out the bronze bushing and install the roller bearing flush with the end of the crank. No more worries about the input shaft seizing inside the bronze bushing.
I've seen the roller pilot bearing come apart, but never a bronze bushing.
