Verify 383 Engine Oil dipstick Lenght #86105
07/08/08 10:26 PM
07/08/08 10:26 PM
Slidell, LA
Ronnman Offline OP
Ronnman  Offline OP
Slidell, LA
Can someone measure there 383 engine oil dipstick to verify my measurements. I measured 23 inches from tip to stop near the handle and 2-1/2 inches from bottom to the full mark. My oil level is higher than the full mark with 5 quarts of oil and new filter.
Thanks,
Ron
Re: Verify 383 Engine Oil dipstick Lenght [Re: Ronnman] #86106
07/09/08 07:47 PM
07/09/08 07:47 PM
Slidell, LA
Ronnman Offline OP
Ronnman  Offline OP
Slidell, LA
BTT
Re: Verify 383 Engine Oil dipstick Lenght [Re: Ronnman] #86107
07/10/08 08:27 AM
07/10/08 08:27 AM
Slidell, LA
Ronnman Offline OP
Ronnman  Offline OP
Slidell, LA
Can someone please help me out?
Re: Verify 383 Engine Oil dipstick Lenght [Re: Ronnman] #86108
07/10/08 08:44 AM
07/10/08 08:44 AM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
Oil dipstick length is not enough. You have to know the tube length also. I just checked that measurements for a friend's 1970 small block last week-end (he had a hand-made mark on his dipstick, almost an inch above the 'Full' mark, and wanted to know if that may be the real Full level. We checked on a friend's 1973 cuda, and both the tube and dipsticks were of different lengths. I measured from the water pump top with a ruler (of course, you can't do that with a BB, but you can probably find a reference point, like the bottom of the valve cover). Sure enough, the hand-made mark was the right one compared to the 73. Almost 1.5 liter above the stamped 'Full' mark.
5 to 6 quarts seems nominal for a stock 383 pan (bigger pans : hemi is at 6, deep aftermarket units are at 7 and beyond).
With a new filter, I'd say pour in 6 quarts and make your own 'Full' mark.
Re: Verify 383 Engine Oil dipstick Lenght [Re: Ronnman] #86109
07/10/08 08:53 AM
07/10/08 08:53 AM
mabey cause your 383 only needs 4 1/2 quarts of oil.
Re: Verify 383 Engine Oil dipstick Lenght #86110
07/10/08 09:28 AM
07/10/08 09:28 AM
Slidell, LA
Ronnman Offline OP
Ronnman  Offline OP
Slidell, LA
Well the service manual and owners manual both state 5 quarts with new filter. I still would like to know the lenght of the dipstick. I know the tube lenght matters, but I need to start somewhere. Since its easier to measure the dipstick thats where I'am at.
Ron
Re: Verify 383 Engine Oil dipstick Lenght [Re: Ronnman] #86111
07/11/08 10:47 AM
07/11/08 10:47 AM
Slidell, LA
Ronnman Offline OP
Ronnman  Offline OP
Slidell, LA
Any help available?
Re: Verify 383 Engine Oil dipstick Lenght [Re: Ronnman] #86112
07/11/08 12:15 PM
07/11/08 12:15 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Ron,
Hang on.... I'll brb with a pic of my original '70 383 stick.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Verify 383 Engine Oil dipstick Lenght [Re: R70RUNNER] #86113
07/11/08 12:27 PM
07/11/08 12:27 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Stick lenghth... Pick your point of ref
Re: Verify 383 Engine Oil dipstick Lenght [Re: R70RUNNER] #86114
07/11/08 12:29 PM
07/11/08 12:29 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Stick marks... Jezzz I should charge for this service HTH
Re: Verify 383 Engine Oil dipstick Lenght [Re: R70RUNNER] #86115
07/11/08 12:56 PM
07/11/08 12:56 PM
Slidell, LA
Ronnman Offline OP
Ronnman  Offline OP
Slidell, LA
Thanks a bunch! I own you one R70RUNNER.
Ron
Re: Verify 383 Engine Oil dipstick Lenght [Re: Ronnman] #86116
07/11/08 01:16 PM
07/11/08 01:16 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
No problem-o, sorry I don't have the original tube any longer to help with that info. Hope you get it sorted out
Re: Verify 383 Engine Oil dipstick Lenght [Re: R70RUNNER] #86117
07/11/08 03:11 PM
07/11/08 03:11 PM
Slidell, LA
Ronnman Offline OP
Ronnman  Offline OP
Slidell, LA
I think your measurements versus my dipstick account for the elevated oil level. Thanks again.
Ron
