Pittman Arm Help! #860920
11/22/10 09:07 PM
11/22/10 09:07 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I have a 66 BelvedereII that I'm converting to power steering. I got the steering column and I purchased a Power Steering gearbox from the local parts store. The Gearbox was for a 68 Charger but my buddy told me it would bolt right up. It does bolt up and all but the Pittman arm is too small. The length is fine but my pittman arm shaft on the power steering gearbox is slightly bigger. Anyone have a used one or where can I get one?
Re: Pittman Arm Help! [Re: roy2345] #860921
11/22/10 10:44 PM
11/22/10 10:44 PM
BDW Offline
BDW  Offline
If it's not too late get a later year box with the larger diameter pitman arm. Parts are much cheaper and easy to find.
http://www.allpar.com/history/mopar/steering-chuck.html
Re: Pittman Arm Help! [Re: BDW] #860922
11/22/10 10:50 PM
11/22/10 10:50 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Check your pm's.
Keith
Re: Pittman Arm Help! [Re: BDW] #860923
11/22/10 10:51 PM
11/22/10 10:51 PM
get a new PS pitman arm for a '68 charger at your parts house
Re: Pittman Arm Help! [Re: RapidRobert] #860924
11/22/10 11:42 PM
11/22/10 11:42 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
i been looking and they seem to start using the larger diameter in 73. So will a 73 pittman arm for a charger work on my setup?
Re: Pittman Arm Help! [Re: roy2345] #860925
11/24/10 12:41 AM
11/24/10 12:41 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
It sounds to me like they sold you the wrong steering gear. Until 1973 A and B bodies used the same size sector shaft (output) but full size cars used a larger one. All cars used the larger size for power steering starting in '73. It was probably just a boxing mixup.
Re: Pittman Arm Help! [Re: @#$%&*!] #860926
11/24/10 06:34 PM
11/24/10 06:34 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
The box is for a 69 full size dodge that they sold me. So what Pittman arm do I need to get? They sold me one for a Cbody car...So do I get a Cbody pittman arm?
Re: Pittman Arm Help! [Re: roy2345] #860927
11/27/10 01:59 AM
11/27/10 01:59 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I don't believe the C Body arm will work at all in a B body. You need to get the proper B Body box and pitman arm........
Re: Pittman Arm Help! [Re: RapidRobert] #860928
11/27/10 11:50 AM
11/27/10 11:50 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not a chance they have it and if..IF you can find them new they are $$$$$ I ordered 2 and both were WRONG. eneded up using one I had on and old PS unit.
Coming soon!!!!
Re: Pittman Arm Help! [Re: roy2345] #860929
11/27/10 03:07 PM
11/27/10 03:07 PM
Thigh-Gap Junction
@#$%&*! Offline
@#$%&*!  Offline
Thigh-Gap Junction
Yep, they sold you the wrong box. There is a pitman that will work as Firm Feel has been pushing the large-sector boxes for this app. for a while now. If your pitman is good, just make them swap you for the right steering gear--NOT for a full size car, tell them what your car is and the correct year. If your pitman is toast, keep the steering gear they sold you and find the large-sector pitman that fits. I think the app. is either A or B-body, '73-up POWER STEERING. You could call firm feel and ask but they'd want to sell you one and probably not just tell you the part number.
Re: Pittman Arm Help! [Re: @#$%&*!] #860930
11/29/10 06:51 PM
11/29/10 06:51 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Thanks and one is on the way. I'll update later this week when it gets here.
Re: Pittman Arm Help! [Re: roy2345] #860931
12/03/10 09:35 PM
12/03/10 09:35 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
It arrived today and fit perfect! It was $25 to my door brand new. It was for a 73 Charger but it fit my box for my application. Mix and match is one more reason I love MOPAR
