Page 4 of 26 1 2 3 4 5 6 25 26
Re: 71 cuda pro touring project [Re: johnscudashop] #859894
05/08/11 04:10 PM
05/08/11 04:10 PM
Mrytle Beach SC
johnscudashop Offline OP
Mrytle Beach SC
Another view
Re: 71 cuda pro touring project [Re: JDMopar] #859895
05/13/11 10:11 PM
05/13/11 10:11 PM
Myrtle Beach, SC
DRED Offline
DRED  Offline
Myrtle Beach, SC
I love the build. Thinking of doing something similar. Looks like you're doing a great job. I am learning a lot from it. Keep up the good work!!
Re: 71 cuda pro touring project [Re: johnscudashop] #859896
05/14/11 07:17 PM
05/14/11 07:17 PM
QLD Australia
Keith Black® Offline
QLD Australia
[quoteThe quicktime bell doesn't fit because the Magnum has 2 oil pump bosses in the .
i had this problem, we managed to machine the bell. QT gave us the CAD info to machine it apparently all the new bell's are machined to fit.
Nice project
Darren Beale
Keith Black Racing Engines®
Re: 71 cuda pro touring project [Re: Keith Black®] #859897
05/15/11 07:56 PM
05/15/11 07:56 PM
Mrytle Beach SC
Mrytle Beach SC
Yes As I know. Keisler had some quicktime bellousings that didn't have this provision in it. They rectified the problem with the aluminum belhousing. it would be great if you could post some pictures of your T56 install, tunnel and crossmember modifications.Yours looks great too
Re: 71 cuda pro touring project [Re: johnscudashop] #859898
05/18/11 05:59 PM
05/18/11 05:59 PM
Mrytle Beach SC
Mrytle Beach SC
Before the motor goes in, I wanted to do most of the sheet metal work the engine compartment needed. Looks like the LH inner fender and the upper cowl needs to be replaced.I spent the day drilling spot welds and carefully removing the sheet metal with a hand chisel. This is as far as I got today.
Re: 71 cuda pro touring project [Re: johnscudashop] #859899
05/18/11 06:00 PM
05/18/11 06:00 PM
Mrytle Beach SC
Mrytle Beach SC
Upper cowl removal
Re: 71 cuda pro touring project [Re: johnscudashop] #859900
05/19/11 05:38 PM
05/19/11 05:38 PM
Mrytle Beach SC
Mrytle Beach SC
Today I spent the day grinding down welds and filling holes, I Mocked the vintage air unit to the firewall. Instead of drilling holes I took a piece of 1/8 X 1" X 12" welded 2 studs so I can hang the unit.
Re: 71 cuda pro touring project [Re: johnscudashop] #859901
05/19/11 05:39 PM
05/19/11 05:39 PM
Mrytle Beach SC
Mrytle Beach SC
Mocked up Vintage air unit
Re: 71 cuda pro touring project [Re: johnscudashop] #859902
05/25/11 03:22 PM
05/25/11 03:22 PM
Mrytle Beach SC
Mrytle Beach SC
I moved The Cowl to inner fenderwell bars so I can gain some tire clearance. What I did was mounting them thru the lower cowl and into the lower inner kick panel support. It is supported there with 1/8 plate and also the upper cowl where it comes thru the firewall.
Re: 71 cuda pro touring project [Re: johnscudashop] #859903
05/25/11 03:23 PM
05/25/11 03:23 PM
Mrytle Beach SC
Mrytle Beach SC
inner kick panel support area
Re: 71 cuda pro touring project [Re: johnscudashop] #859904
05/25/11 03:25 PM
05/25/11 03:25 PM
Mrytle Beach SC
Mrytle Beach SC
1" Tire clearance at maximum suspension travel
Re: 71 cuda pro touring project [Re: johnscudashop] #859905
05/25/11 03:26 PM
05/25/11 03:26 PM
Mrytle Beach SC
Mrytle Beach SC
rear view
Re: 71 cuda pro touring project [Re: johnscudashop] #859906
05/26/11 03:35 PM
05/26/11 03:35 PM
Mrytle Beach SC
Mrytle Beach SC
I cut out and made some patches for the lower cowl. After I carefully fitted and welded them. I blasted and coated the cowl rust bullet, Scuffed the surface then epoxy primer. I used weld thru primer on all areas that will be welded.
Re: 71 cuda pro touring project [Re: johnscudashop] #859907
05/26/11 03:35 PM
05/26/11 03:35 PM
Mrytle Beach SC
Mrytle Beach SC
welded patches
Re: 71 cuda pro touring project [Re: johnscudashop] #859908
05/26/11 03:37 PM
05/26/11 03:37 PM
Mrytle Beach SC
Mrytle Beach SC
Blast, Rust bullet ,epoxy primer and weld thru primer
Re: 71 cuda pro touring project [Re: johnscudashop] #859909
05/26/11 05:40 PM
05/26/11 05:40 PM
Washington
19cuda73 Offline
19cuda73  Offline
Washington
Looking Good John very similiar to the same rust areas I had on my car in the cowl area. Keep up the good work..I Enjoy looking at your progress
Dennis
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: 71 cuda pro touring project [Re: 19cuda73] #859910
05/27/11 03:57 PM
05/27/11 03:57 PM
Mrytle Beach SC
Mrytle Beach SC
I drilled the panels for rosett type spot welds ,I added more the the factory. The AMD upper cowl and inner fender are dead on needing only minor tweeking. I plan on welding the full seam and then blend it into the lower cowl.I left the end were the hood hinges weld to unwelded for now as I will weld them in when I fit the hood to the fenders.
Re: 71 cuda pro touring project [Re: johnscudashop] #859911
05/27/11 03:58 PM
05/27/11 03:58 PM
Mrytle Beach SC
Mrytle Beach SC
Inner fender
Re: 71 cuda pro touring project [Re: johnscudashop] #859912
05/27/11 04:00 PM
05/27/11 04:00 PM
Mrytle Beach SC
Mrytle Beach SC
AMD upper cowl,fitted and ready for welding
Re: 71 cuda pro touring project [Re: johnscudashop] #859913
05/27/11 04:01 PM
05/27/11 04:01 PM
Mrytle Beach SC
Mrytle Beach SC
AMD inner fender fitted and ready for welding
