Orange peel questions/technique questions
#859818
11/21/10 08:39 PM
11/21/10 08:39 PM
Posts: 1,070 Newton, KS
70B5Cuda
Newton, KS
I have never used epoxy primer before and I have limited paint experience so tomorrow will be an experiment. Is orange peel typically an air pressure issue or mixture issue or both? What adjustments should be made when I encounter it? What do I start with? What is the sequence? Thanks
Gun is Devilbiss FinishLine 3 HVLP. Paint is DP90LF
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
Re: Orange peel questions/technique questions
[Re: 70B5Cuda]
#859822
11/21/10 10:15 PM
11/21/10 10:15 PM
Why are you worried about orange peel in primer? You're going to have to scuff epoxy to get filler primer to "bite" properly followed by numerous coats and block sanding of the filler primer so it really doesn't matter?!
[Re: racerx]
#859826
11/23/10 01:34 PM
11/23/10 01:34 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
For me, orange peel has become a useful tool in helping to know how much to wetsand before buffing. Virtually all new cars have it on their finish coats and they have for some time.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
