Hardblok on a RB Block #859798
11/21/10 08:19 PM
11/21/10 08:19 PM
charlotte nc
jimmysarrow Offline OP
charlotte nc
How high does everybody fill their block with hardblok, just above the freeze plugs or up to the bottom water pump hole on a 440 block?
Re: Hardblok on a RB Block [Re: jimmysarrow] #859799
11/21/10 08:24 PM
11/21/10 08:24 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Thats the builders preference, but typically a race motor to the pumps, a street/strip motor to the plugs, or halway if you will.
RIP Monte Smith
