Which Dyno Chassis Or Engine? #859596
11/21/10 07:30 PM
11/21/10 07:30 PM
Burlington,Ont.
77DragracerR/T Offline OP
Burlington,Ont.
I don't have any info on my motor and would like to have it dynoed.Would a engine dyno give better info or should i leave the engine in the car and run on a chassis dyno. My other concern is my converter flashes to 5400 so would that mean i wouldn't have any info below 5400? 408 with 590 cam and mildly ported eddy heads.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Which Dyno Chassis Or Engine? [Re: 77DragracerR/T] #859597
11/21/10 08:02 PM
11/21/10 08:02 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Personally if I have a choice I'd rather go on an engine dyno. There are way too many variables with a chassis dyno.
Re: Which Dyno Chassis Or Engine? [Re: slantzilla] #859598
11/21/10 08:12 PM
11/21/10 08:12 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
A couple of 1/4 mile passes will tell the pertinate facts.
Re: Which Dyno Chassis Or Engine? [Re: B G Racing] #859599
11/21/10 09:21 PM
11/21/10 09:21 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The engine dyno seems like the better of the two choices. If something is going to leak or need fixed I think I'd rather find out before the engine goes in the car.
Re: Which Dyno Chassis Or Engine? [Re: Neil] #859600
11/21/10 09:38 PM
11/21/10 09:38 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Hands down a chassis dyno. Its your complete car on the chassis dyno so you get to see if all of your stuff is working properly versus the engine dyno that is using its igniton, fuel system .......
On the chassis dyno you can see everything and don't have to worry about where you are going.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Which Dyno Chassis Or Engine? [Re: 77DragracerR/T] #859601
11/21/10 09:41 PM
11/21/10 09:41 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Personally,I think an engine dyno is the way to go.
I put a lot of research into it,and bought a Superflow engine dyno so I could do alot of testing and hopefully learn some things to help myself,and customers and friends out.
Some people will argue that chassis dynos are accurate,but I disagree.I won't eat up this whole post with why,so I will leave it at this;
An engine dyno that is properly calibrated and run by an operator with the correct procedures is the most accurate way to test an engine.
I hope this helps you in some way.
Keith
Re: Which Dyno Chassis Or Engine? [Re: Dunnuck Racing] #859602
11/21/10 10:35 PM
11/21/10 10:35 PM
sg66mopar Offline
sg66mopar  Offline
I can't argue with Keith at all.
That being said, the chassis dyno helped me find a gremlin in my engine - transmission combination that I had chased for over a whole season. This was a major gremlin and I don't know when I would have found it otherwise, but the engine dyno would NEVER have found it.
At the same time it allowed me to get the plugs, jetting and timing dialed in, which I know I could have done on an engine dyno.
There are down sides to the chassis dyno. Lots of tire wear. Cooked tranny fluid if you aren't on top of the whole procedure. Stagnant air that skews accuracy. Probably lots of others.
The good news? I only paid $125 for 4 hours on the machine!
Re: Which Dyno Chassis Or Engine? [Re: sg66mopar] #859603
11/21/10 10:44 PM
11/21/10 10:44 PM
Northern Indiana
Northern Indiana
A good part of my reasoning for putting the engine dyno in my shop was so other racers could afford to get an engine dyno tested.
The cost of a day on an engine dyno was not in the budget for most bracket racers.I hope to be able to help out my Moparts buddies and fellow bracket racers on this.
Keith
Re: Which Dyno Chassis Or Engine? [Re: Dunnuck Racing] #859604
11/21/10 10:51 PM
11/21/10 10:51 PM
sg66mopar Offline
sg66mopar  Offline
Keith
So how far are you from Eagle Creek, Oregon. Maybe my new motor can end up on your machine?
Re: Which Dyno Chassis Or Engine? [Re: sg66mopar] #859605
11/21/10 11:06 PM
11/21/10 11:06 PM
Northern Indiana
Northern Indiana
Northern Indiana,a little bit of a haul for you!
I really don't plan on doing stuff for other guys until I get some experience under my belt anyway.
Just started the sheet rock on the Dyno cell today,and have been ordering parts for my "Dyno Mule".
Thanks for the interest though.
Keith
Re: Which Dyno Chassis Or Engine? [Re: 77DragracerR/T] #859606
11/21/10 11:30 PM
11/21/10 11:30 PM
I have used both, bottom line once you close the hood and race the car with a open hood scoop you will have to tune the car at the track At least I have and every one else I know that has used a dyno of either type has, if you want to get the most out of your car at the track. The weather, wind,track conditions and many other things affect the cars performances
Re: Which Dyno Chassis Or Engine? [Re: Dunnuck Racing] #859607
11/21/10 11:37 PM
11/21/10 11:37 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I'm with Keith, As much as I like running it down the track there are to many variables that can affect the data. A chassis dyno has tire slippage, convertor stall, and a few other issues. An engine dyno is much more user friendly when you want to start changing parts and pieces. I bought one primarily for my own quest for answers on my own junk. Along with my own stuff, a few of my friends have some interesting motors that are going on it. Nice thing now is time is no object, if I want to run 50 different tests on a particular motor I can.Dave
Re: Which Dyno Chassis Or Engine? [Re: Cab_Burge] #859608
11/21/10 11:42 PM
11/21/10 11:42 PM
Burlington,Ont.
Burlington,Ont.
Thanks for all the opinions everyone.I see a lot have good points for both uses! My reasoning for thinking of a engine dyno was to send my converter back with torque readings.I've had this converter done twice now and both times are off,too tight,too loose.I had this car on a chassis dyno before and it is helpful to know the ignition in my car and fuel supply are all working accordingly.But i remember the car flashing up to 5000 until the converter locked up but then i only got 5000-6200 reading.I personally believe in the track info but like the idea of actual numbers for the engine.I've been running this combo for 2yrs now and wish i had the info before.Are Mustang chassis dynos good for tuning and getting info from?
Thanks again guys
Re: Which Dyno Chassis Or Engine? [Re: 77DragracerR/T] #859609
11/21/10 11:46 PM
11/21/10 11:46 PM
Burlington,Ont.
Burlington,Ont.
The engine dyno shop up here is $400. for 4hrs. DSE1 runs it and has good views on it's business.
Re: Which Dyno Chassis Or Engine? [Re: 77DragracerR/T] #859610
11/21/10 11:54 PM
11/21/10 11:54 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Sounds like your converter guy is missing something
Re: Which Dyno Chassis Or Engine? [Re: 77DragracerR/T] #859611
11/21/10 11:57 PM
11/21/10 11:57 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
engine dyno if you are looking to do alot of changes to see what really works for a combo.
its a tool to find gains !
most good dyno shops will have different carbs / spacers / etc. to try also to find more power for ya.
Re: Which Dyno Chassis Or Engine? [Re: 77DragracerR/T] #859612
11/22/10 12:00 AM
11/22/10 12:00 AM
Northern Indiana
Northern Indiana
That sounds about right,on average for what most guys charge.A good operator is essential.
Good luck with whatever you decide!
Keith
Re: Which Dyno Chassis Or Engine? [Re: bigtimeauto] #859613
11/22/10 12:00 AM
11/22/10 12:00 AM
Burlington,Ont.
Burlington,Ont.
I think he is too! And it could be the info he was givin so i'd like him to have the correct info so he can do it right.I still have another converter that works great but this other one i want as a back up if needed.I do run a 904 trans and you never know if the converter will break the welds or not as it has happened.
Re: Which Dyno Chassis Or Engine? [Re: 77DragracerR/T] #859614
11/22/10 12:03 AM
11/22/10 12:03 AM
Renton Washington
Triple Threat Offline
Renton Washington
Lots of shops will offer "baseline pulls" basically 2-3 pulls without changes in between to get a handle on what your ar makes power wise and where.
Typically $50-$150 depending on the shop. You dont need 4 hours unless you plan on doing tuning as well.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Which Dyno Chassis Or Engine? [Re: Dunnuck Racing] #859615
11/22/10 06:35 AM
11/22/10 06:35 AM
Europe
BB 70 Challenger Offline
Europe
Keith
Hello Keith. Could you tell me how much would such a complete engine dyno set-up cost (a rough estimate is fine, thanks)?
