Oil pickup touches bottom of pan? #859392
11/21/10 02:11 PM
11/21/10 02:11 PM
Kirkland, Washington
Pacnorthcuda Online boogie OP
Pacnorthcuda  Online Boogie OP
I just read in the FSM that the pickup should touch the bottom of the pan. I always adjusted so that it was just off (maybe 1/8" to 1/4").
Guess I was wrong. What say you?
Re: Oil pickup touches bottom of pan? [Re: Pacnorthcuda] #859393
11/21/10 02:19 PM
11/21/10 02:19 PM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
No way i cant see that being true i never let my pickup hit the pan.
Re: Oil pickup touches bottom of pan? [Re: Dons Dart] #859394
11/21/10 02:41 PM
11/21/10 02:41 PM
In a stock app it's OK as there's plenty of area there for the oil to be drawn in at the scalloped opening. In a perf app I like 1/8" and in an app w very high rpm/hi vol pump/loose clearances even more than 1/8 and I make sure the ID from (& including) the pickup thru every twist & turn right up to the rotors is 5/8" and the output side up to the galleries is 1/2" and any restriction also makes the inter shaft require more torque/wears it & the bushing & cam gear more & can be helped by opening passages. I highly recommend baffles around the sump perimeter and a swinging baffle in the sump bottom is even better but alot of fabbing. I'd drill the angled passages from the main gallery to the mains to 5/16". OT imnho a pan cannot get sucked dry. EDIT I make sure the pickup bottom is parallel w the inside pan bottom as alot of times the angle is quite a bit off & I heat/bend it to get it there.
Re: Oil pickup touches bottom of pan? [Re: Pacnorthcuda] #859395
11/21/10 02:52 PM
11/21/10 02:52 PM
Chesterfield, MIch
Cuda67 Offline
super street
Cuda67  Offline
super street
Chesterfield, MIch
In production the tube contacts the bottom of the pan. If it doesn't hit the pan you run the risk of it breaking off due to virration.
Re: Oil pickup touches bottom of pan? [Re: Cuda67] #859396
11/21/10 03:02 PM
11/21/10 03:02 PM
excellent tip . I will start welding a nut or a spacer on the bottom of the pickup on apps that are off of the bottom to anchor the pickup
Re: Oil pickup touches bottom of pan? [Re: RapidRobert] #859397
11/21/10 03:11 PM
11/21/10 03:11 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The STOCK pickup has a partial shield on the bottom of it. This sets the proper height only if the shield touches the bottom of the pan. That is the way it is designed and setting it higher is improper.
Don't be the exception.
Re: Oil pickup touches bottom of pan? [Re: Pacnorthcuda] #859398
11/21/10 03:11 PM
11/21/10 03:11 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
It depends on style of the pick-up. Factory style can touch. Most others - not.
