B Body oil pan fit question #859289
11/21/10 01:51 PM
11/21/10 01:51 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I want to put a Milododon 7 quart oil pan on my 69 GTX. 440 4 speed car. It is about 2 inches lower than the stock pan. Does anyone use this pan on their B Body and do you have any ground clearance issues? Also, do you recomend this pan?? Would you buy again?? Thanks in advance
Re: B Body oil pan fit question [Re: frank] #859290
11/21/10 02:05 PM
11/21/10 02:05 PM
IA
landon1 Offline
landon1  Offline
IA
i have a generic 7qt which is 2" deeper than stock - looks like a stock pan, cut, with a deeper sump welded on. also much heavier duty metal used than the stock pan, and it was just a $90 one (with pickup - also better design than stock imo. my front end sits close to stock height and i haven't had any issues with ground clearance - i think some people's headers hang lower than my oil pan. the only issue i had was with center link clearance - but the stock pan was all beat-up from the center link, too, so the pan wasn't the issue imo.
'71 Satellite Sebring 440
Re: B Body oil pan fit question [Re: landon1] #859291
11/21/10 03:14 PM
11/21/10 03:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run a 8 qt Moroso on my 65 B body.Its been on at least 15 years and street driven.It has plenty of clearance.I run 165x80x15 frt tires and the front end could still be lifted a few inches if I wanted to.Rocky
Chrysler Firepower
Re: B Body oil pan fit question [Re: frank] #859292
11/21/10 03:19 PM
11/21/10 03:19 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Having the oil pan being the lowest point is never a good idea. I run on of these pans on my 68 Charger and it has hit speed bumps. I plan to extend the factory skid plate to protect it.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: B Body oil pan fit question [Re: HemiRick] #859293
11/21/10 06:16 PM
11/21/10 06:16 PM
QLD Australia
Keith Black® Offline
QLD Australia
use the milodon #31580:
Darren Beale
Keith Black Racing Engines®
Re: B Body oil pan fit question [Re: Keith Black®] #859294
11/21/10 07:09 PM
11/21/10 07:09 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I would if it didn't cost so much. I was looking at the Milodon 30930
