So are Hemis more prone to detonation then wedges?
#85906
07/08/08 05:37 PM
07/08/08 05:37 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Some one in the restoration/A12 section brought up a point about Hemi combustion chambers being more detonation resistant and was wondering what everyones thoughts on this theory are.
I read Bill Weertman's book on the History of Chrysler Engines. He was discussing the early theories regarding open chamber combustion chambers including the Hemi and how the thought was that they were more prone to detonation due to the lack of squish (turbulence). He goes on to say that their tests, however, showed that because of the surface area to volume ratio of the hemi and the spark plug location, the squish (and detonation problem) was negated.
I read another article on detonation where they again mentioned the Chrysler Hemi. In this article they state that while the lower compression pistons in the 2G Hemi could run reasonable timing, the high compression pistons needed to run considerably more total timing to make up for the the flame front disruption caused by the domes on the piston. Severe detonation could occur unless fuel with the proper octane was used.
Now, in my case, I have aluminum heads, 9.5 compression running on 94 octane fuel. With 34 degrees of total timing, curved with the timing all in by 2000 rpm, 3.54 gears, a 4 speed in a 3800 lb car, and running at 180 degree temperature, I can get the engine to ping slightly by dropping the rpm down to 2000 rpm in 3rd or 4th gear and winging the throttle quickly. I corrected this by changing the dizzy springs so the curve is all in by 2600 RPM. I can get a quick little ping going up 5% grade in 4th gear going about 50 MPH (2300 rpm), and open up the throttle a little.
Gentlemen (and ladies) start ur discussion!
Re: So are Hemis more prone to detonation then wedges?
[Re: ScottSmith_Harms]
#85909
07/08/08 05:54 PM
07/08/08 05:54 PM
torkrules
I'm neurotic
I'm neurotic
Is your compression actual? What I'm asking is, are your pistons 9.5:1 or is your ACTUAL compression 9.5:1?
Yes, it was measured using a buret and blue dyed alcohol.
[Re: Magnum]
#85911
07/08/08 05:58 PM
07/08/08 05:58 PM
torkrules
I'm neurotic
I'm neurotic
That's alot of timing for climbing a hill in high gear.
Maybe so, but how was it done back in the day? What sort of curve was used in a stock Hemi dual point distributor? What total timing was used? What octane was used with 10.2 compression?
Maybe I'm still thinking automatic where the torque converter was drastically reduce the load therefore no detonation under any circumstances. Maybe the driving habits need to change (hold it in 3rd gear at 3000 rpm until I hit the top of the incline)
[Re: lewtot184]
#85913
07/08/08 06:41 PM
07/08/08 06:41 PM
a hemispherical chamber is more detonation resistant. piston quench area can be achieved on a hemi just like a wedge.
your kidding right?
#85914
07/08/08 06:50 PM
07/08/08 06:50 PM
dogdays
A hemi has the spark plug in the center. That's good. It has a long way for flame travel. That's bad. It is possible to get squish in a Hemi by running the piston close to the head surface farther away from the spark plug. That's good. Most Hemis have combustion chambers flattened out over the top of the piston. That's bad. The supposition that a hemi has the least surface-to-volume ratio is only true if the combustion chamber looks like a hemisphere. If it looks like part of an orange peel it has a HIGH surface to volume ratio. Look at www.theoldone.com to see a good hemispherical combustion chamber developed for a ford Boss 429. R.
[Re: dogdays]
#85915
07/08/08 06:55 PM
07/08/08 06:55 PM
no comparison. boss 429 has a much much better chamber then the hemi. but kudos for the link.
[Re: lewtot184]
#85916
07/08/08 07:07 PM
07/08/08 07:07 PM
torkrules
I'm neurotic
I'm neurotic
i think this is a valid point. If the piston where brought up closer to the head (adjacent to the valves) I would think some turbulence can be induced into the mixture which I think would be beneficial.
[Re: quickd100]
#85919
07/08/08 08:08 PM
07/08/08 08:08 PM
torkrules
I'm neurotic
I'm neurotic
Forget your compression ratio, what's the cylinder pressure? I'm guessing you're running a fairly small cam with a short duration figure. That will build cylinder pressure. My old stock 426 was a measured 9.56-1, with the stock cam it would ping under load too with standard grade gasoline. Dave
That's a good point! I haven't done a compression check, but the cam I'm using is an Engle hydraulic K8 which has .564 lift and 248 duration at .050 and 106 degree lobe seperation. Not sure if this would be considered a pressure killing or building cam. I'm also using the Landy rockers which increases the lift slightly (If I'm not mistaken it's 1.6 Intake, 1.55 exhaust which would increase the lift to .593)
#85920
07/08/08 08:27 PM
07/08/08 08:27 PM
Posts: 3,916 usa
lewtot184
usa
your kidding right?
just a joke hope you enjoyed it
[Re: lewtot184]
#85921
07/08/08 08:53 PM
07/08/08 08:53 PM
Posts: 21,843 Kirkland, Washington
Pacnorthcuda
your kidding right?
I think it was over his head.
[Re: Pacnorthcuda]
#85922
07/08/08 08:57 PM
07/08/08 08:57 PM
your kidding right?
think again friend. how much CR are you gonna get with .040" (ideal quench) piston->chamber clearance in a hemi? so in this case..ur way outta ur league.
