Re: !!!!! new Best!!! but not with out brakeage. [Re: 69CHARGERMD] #858760
11/21/10 08:30 PM
11/21/10 08:30 PM
Central Missouri Fort Leonard...
mopar65 Offline OP
mopar65  Offline OP
thanks doug. i hopw to get it faster yet. but glad i did not call out a someones white 65 plymouth. did not want to get my butt handed to me lol.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: !!!!! new Best!!! but not with out brakeage. [Re: mopar65] #858761
11/21/10 08:47 PM
11/21/10 08:47 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
Congrats there sarge and don't forget to check that tranny after puking a rearend , especially look at the sprag. Time for that Dana 60 now ! Good luck
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: !!!!! new Best!!! but not with out brakeage. [Re: 65dragnet] #858762
11/21/10 09:11 PM
11/21/10 09:11 PM
mopar65 Offline OP
mopar65  Offline OP
thanks for the kind words and will do on the trans.I think its time to put a billet front drum in it while i am at it.thanks SGT miller
Re: !!!!! new Best!!! but not with out brakeage. [Re: mopar65] #858763
11/21/10 09:28 PM
11/21/10 09:28 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I told you what it would run..
now get a big ole DANA in there and some traction bars and let it all hang out..
get that fuel system straightened out and bam..10.40's or better
Re: !!!!! new Best!!! but not with out brakeage. [Re: joedust451] #858764
11/22/10 01:19 AM
11/22/10 01:19 AM
mopar65 Offline OP
mopar65  Offline OP
ok here are the times of all of my runs. please look them over and tell me what you think or see wear i might see some improvement.thanks Bobby
(1) pass
60 FT ---- 1.5723
330 FT ---- 4.5206
1/8 ET ---- 7.0054
1/8MPH ---- 98.21
1000 ET ---- 9.1684
1000 MPH ---- 112.53
1/4 ET ---- 10.8901
1/4 MPH ---- 122.65
(2)
60 FT ---- 1.5727
330 FT ---- 4.4758
1/8 ET ---- 6.9226
1/8 MPH ---- 100.29
1000 ET ---- 9.0544
1000 MPH ---- 113.84
1/4 ET ------ 10.7595
1/4 MPH ---- 123.66
(3) best pass
60 FT ---- 1.5479
330 ---- 4.4357
1/8 ET ---- 6.8723
1/8 MPH ---- 100.74
1000 ET ---- 8.9938
1000 MPH --- 114.68
1/4 ET ----- 10.6859
1/4 MPH ---- 124.58
(4)
60 FT ---- 1.5509
330 FT ---- 4.4450
1/8 ET ---- 6.8883
1/8 MPH --- 100.33
1000 ET ---- 9.0184
1000 MPH --- 114.04
1/4 ET ------- 10.7236
1/4 MPH ----- 123.56
Bobby, looks like you might be having traction problems too, i'm sure it spun on the 1st. pass for sure. Your also really picking up on the last 660 on each run, so you may want to try lowering the shift points if your trapping lower then where your shifting, if it slows with a lower shift point then you can use a steeper gear, you normally want to trap 2-300 RPMs over the shift points, not below it.
Sorry your 8.3/4 bit the dust, i'm sure there was something going out because it should easily be able to handle 1.5s 60fts. for a long time in a light car.
hey joe thanks for the info. i wish you could of made it to the race. i think it would be cool if we could get a pic of our cars togeather. but yes looks like i have a lot of stuff to sort out next year. my goal is to get it to run 10 flat in the 1/4 but still drive it on the street. but i dont know if i will be able to do it with this motor or not.but i would be real happy to run 10.50 in thw 1/4 and take it for a ride around town once in a while.
Re: !!!!! new Best!!! but not with out brakeage. [Re: smokinwoody] #858765
11/22/10 01:23 AM
11/22/10 01:23 AM
mopar65 Offline OP
mopar65  Offline OP
thanks ted. yep looks like i have a lot of soarting out to do on the car next spring. I would love to put a dana in it and some ladder bars at the same time.also if it gets any faster i might have to upgrade the brakes with some wilwoods etc.because trying to stop the car going 125 mph at my home track was starting to get a little scary.or i just was not used to running that fast in slong long i for got what is was like.
Re: !!!!! new Best!!! but not with out brakeage. [Re: mopar65] #858766
11/23/10 12:53 AM
11/23/10 12:53 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Congrats Bobby, that's a fantastic maiden voyage ! Mid 10's in a street combo on the first day !
Ron
