Paint gun cleanup. #858735
11/20/10 10:11 PM
11/20/10 10:11 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
what do u use?4 urethane base paints.Thaxx
Re: Paint gun cleanup. [Re: racerx] #858736
11/20/10 10:40 PM
11/20/10 10:40 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i use acetone, and a small stiff bristle brush.
Re: Paint gun cleanup. [Re: Golden-Arm] #858737
11/20/10 10:56 PM
11/20/10 10:56 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
Use gun cleaning solvent you can get it at your auto paint supply place. I use Omni MS251 ( about $15 a gallon ) I used acetone and reducer for years then I tried gun cleaning solvent and WOW what a difference gun clean up takes half the time and the gun is actually clean. You will be amazed at what else it works on removes Graffiti,makes rubber parts look like new, over spray,takes water spots off windows ETC ETC I try it on everything and it usually works. Did I sound like a late night T.V commercial ?
Re: Paint gun cleanup. [Re: racerx] #858738
11/20/10 11:01 PM
11/20/10 11:01 PM
Hartford,MI
goody340g Offline
goody340g  Offline
Hartford,MI
xylene
Re: Paint gun cleanup. [Re: goody340g] #858739
11/23/10 11:35 AM
11/23/10 11:35 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxx
