Page 2 of 3 1 2 3
Re: Ongoing push rod cup oiling problem. [Re: Von] #858609
11/21/10 02:49 AM
11/21/10 02:49 AM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Do your rockers have a machined channel on the inside circumference for the oil to flow?
Re: Ongoing push rod cup oiling problem. [Re: jb500] #858610
11/21/10 07:13 AM
11/21/10 07:13 AM
Sydney, Australia
B-STUNG Offline
B-STUNG  Offline
Sydney, Australia
I was burning pushrod cups on my engine. I found the oil feed for the pushrod cup did not intersect the oil channel. The picture (attached) might explain it better.
Re: Ongoing push rod cup oiling problem. [Re: B-STUNG] #858611
11/21/10 07:17 AM
11/21/10 07:17 AM
Sydney, Australia
B-STUNG Offline
B-STUNG  Offline
Sydney, Australia
The pushrod cup oil hole should intersect the oil channel like this image (attached).
Once I chamfered the oil hole to ensure it intersects the oil channel, I got a good supply of oil to the cups and stopped burning pushrods.
Re: Ongoing push rod cup oiling problem. [Re: B-STUNG] #858612
11/21/10 11:22 AM
11/21/10 11:22 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
B stung, very good drawing and I had more or less the same thought while asleep. I know the BS head Dove rockers dont have a oiling channel in them. After banana grooving the shafts things improved, some, but not enough. The current rockers do have a channel, but I'll pull one off to see how it looks in relation to your pic.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Ongoing push rod cup oiling problem. [Re: Twostick] #858613
11/21/10 11:24 AM
11/21/10 11:24 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
One other thing. Is the rocker and the shaft oiling ok as in not trying to seize to the shaft?
Kevin
Yes, the rockers and shafts are oiling OK. The tips are getting plenty of oil.
Re: Ongoing push rod cup oiling problem. [Re: Hemiroid] #858614
11/21/10 11:30 AM
11/21/10 11:30 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Well, it's really a pretty simple process of elimination. If you remove the stud from the oiling pedestal and you see a foot tall shot of oil shoot out then you know you're getting a supply of oil from the cam and through the block/head passages.
The next thing to check is if you remove the stud and replace it with a bolt does it change anything? Is the o.d. of the stud bigger than the o.d. of the bolt where the threads end? Also need to check the shaft holes to make sure they're all open and that there's no obstructions inside.
Also I saw you mention that it's not possible that the amount of adjuster out of the rocker is causing a problem. I disagree as I've seen this cause the exact failures you're encountering. If the adjuster is too long out of the bottom it can fling the oil off before it ever makes it to the cup. I know it seems impossible but it happens. It's kind of rocker specific as different rockers oil differently. Some will provide enough oil no matter how long the adjuster, and others will smoke cups if the length isn't perfect.
Not enough oil coming out of the back of the rockers at this point for it to be a length problem...as far as I can tell.
With the first set of rockers, as I said I had 3 different lengths of pushrods and the oiling didnt change a bit. I also swapped adjusters to see if it made a difference, it didnt.
As far as the bolts, studs, etc. Ive had stock bolts in it, socket head bolts and now studs.
With the current configuration (rockers, studs, shafts, hold downs, spacers, etc) it has the least amount of flow.
Re: Ongoing push rod cup oiling problem. [Re: Von] #858615
11/21/10 11:35 AM
11/21/10 11:35 AM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
Had the same promblem,if you are running a roller with alot of spring pressure say over 600lbs you will have this happen. I connected oil passages with dremels 3 sets of pushrods later and broker rockerarms. I got T&DS going strong for 2 years now.
Re: Ongoing push rod cup oiling problem. [Re: B-STUNG] #858616
11/21/10 11:58 AM
11/21/10 11:58 AM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Same issue I had with a set of Indy/Dove rockers last year. I ground feed channels to connect the oil holes to the main channel. Pushrods and valve tips got plenty of oil after that mod.
However, the rockers still failed after a short time frame. The shafts supplied were not hard chrome finished and the bottom of the rockers got eaten up. Cam I run is a Bullet solid FT with .600 lift-nothing crazy. Get the rockers off and check the floor of the rocker bore.
Got to have hard chrome shafts when running aluminum rockers (non bushed or non-needle). Got that info from Dove Mfg directly as well as Mancini.
Made the switch to HS and all rocker concerns have been lost....for now.
Re: Ongoing push rod cup oiling problem. [Re: jb500] #858617
11/21/10 12:08 PM
11/21/10 12:08 PM
UK
602heavy Offline
602heavy  Offline
UK
Von , i remember you're post way back regards you're oiling issues , tis a pain you have'nt got to the bottom of this , i also had to open oil feed channel to enable stand to line up with head...............i fought a long battle regards pushrods getting burnt up , problem was adjuster was tool steel which just ate up 3 sets of pushrods , in the end Manton made me a set of pushrods with tool steel cups , no more issues.
Re: Ongoing pushrod cup oiling problem. [Re: Von] #858618
11/21/10 12:19 PM
11/21/10 12:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I didn't read every post so I don't know if this has been mentioned?
If plenty of oil, then I would bet there's a difference in rocker arm cup and the push rod end. There not the same radius, the cup and the push rod has different radius. Seen this before and might be your problem. My
Re: Ongoing pushrod cup oiling problem. [Re: Challenger 1] #858619
11/21/10 12:33 PM
11/21/10 12:33 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
If you'd have bought Harland Sharp's like I told you years ago I bet you wouldn't be having this problem......... ........I KNOW you've got the money.....PVP......
If you can't handle the truth, you're living a lie.......
Re: Ongoing pushrod cup oiling problem. [Re: Big Squeeze] #858620
11/21/10 12:37 PM
11/21/10 12:37 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yup cheap rocker arms cause these kinds of problems...
Re: Ongoing pushrod cup oiling problem. [Re: Big Squeeze] #858621
11/21/10 12:46 PM
11/21/10 12:46 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
If I was gonna buy a set of HS, they dang sure wouldnt be for this motor.....
Re: Ongoing pushrod cup oiling problem. [Re: Von] #858622
11/21/10 12:54 PM
11/21/10 12:54 PM
Cincinnati, Ohio
Cincinnati, Ohio
What does the motor matter? Low or hi hp, you can't run with burnt up push rods...
And another thing to consider. Once the push rod turns blue, the cup or adjuster in the rocker arm is junk too.
Re: Ongoing pushrod cup oiling problem. [Re: Challenger 1] #858623
11/21/10 01:02 PM
11/21/10 01:02 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
[quote
What does the motor matter? Low or hi hp, you can't run with burn up push rods...
Umm, cuz Ive got a BS head 512 in the works...Not gonna put down 6 bills on a set of rockers that might not see any use. As far as Im concerned the car can sit till the other motor is ready. Based on the fact that the block has been at the machine shop for 10 months and nothing has happended, might be awhile.
Re: Ongoing pushrod cup oiling problem. [Re: Von] #858624
11/21/10 01:07 PM
11/21/10 01:07 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
BTW, how do you tell if a shaft is of the hardened chrome variety?
The shafts I have now are supposedly MP hardened chrome, but I dont know that for sure.
Re: Ongoing pushrod cup oiling problem. [Re: Von] #858625
11/21/10 01:27 PM
11/21/10 01:27 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
The finish should be shiny and smooth. Not machined finish or polished smooth, but chrome bumper/ hyd cylinder rod smooth. It is a hard chrome plating and not of the same variety that bumpers and such use. This stuff is most likely 50rc or better.
Try hitting the shaft lightly with a file and see if you can score the finish. If not....most likely HC plated, if it scratches easily probably not HC plated.
Hit the web and search for Industrial Hard Chrome Cylinder Rod and look at diferent pics for a better visual reference of what HC plating looks like.
Re: Ongoing pushrod cup oiling problem. [Re: Von] #858626
11/21/10 11:37 PM
11/21/10 11:37 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
i'd just put back on the rockers that werent burning up pushrods.......and run it.
Re: Ongoing pushrod cup oiling problem. [Re: fast68plymouth] #858627
11/21/10 11:39 PM
11/21/10 11:39 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
That would seem logical, cept the ratio only worked out to 1.39...
Big seat of the pants difference between the 1.39s and 1.58s...
Re: Ongoing pushrod cup oiling problem. [Re: Von] #858628
11/21/10 11:41 PM
11/21/10 11:41 PM
So. Burlington, Vt.
So. Burlington, Vt.
cams are cheaper that rockers
(well....cheaper than new rockers anyway)
Page 2 of 3 1 2 3
