Re: Ongoing pushrod cup oiling problem.
[Re: fast68plymouth]
#858629
11/23/10 01:53 AM
11/23/10 01:53 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Well I started from scratch to see how much oil is coming to the up. I started with the drivers side as that is the side that has had more problems with cup issues. I modified the oiling passages on both rockers on #1 so I could see if cutting passages would help with oiling. Brought the crank around till the driver side was oiling. The modified rockers have 4-5 more times of oil coming from them than the rest. Volume doesnt seem to be the problem, motor is getting plenty of oil to the top. Now here is where I dont have a clue. On both rockers that I modified, oil was pouring out the back of the rocker, but none of it was hitting the cup. I took the pushrod out and shortened the adjuster till there was almost nothing hanging out to see if the adjuster would ever catch any oil. It never caught a drop. But, can you tell from just priming it if the cup will really receive oil when running? Opinions?? The non modified rockers just drip oil out the back...not much coming from them.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Biginchmopar]
#858631
11/23/10 03:00 AM
11/23/10 03:00 AM
BradH
I hate to be the one that breaks the news to you but the pushrods will never live with cups if you run valve spring pressures over 500lbs open.
I'm sure there are plenty of people on this board who run cup-style pushrods at higher spring pressure than that w/o issues. I don't think it's that cut-and-dry of a solution.
[Re: HEMIFRED]
#858634
11/23/10 04:29 AM
11/23/10 04:29 AM
Posts: 1,805 ky hills
thehemikid
ky hills
...Fwiw ...6yrs on the street with a small .575 roller. The last 2yrs were with the 1.6 H/S rocker's & the same P/rods & cups. ...Mine was light duty compared to the big rollers, but I had no cup/ball problems even though the rods got cut a little short.
[Re: Biginchmopar]
#858639
11/24/10 01:19 AM
11/24/10 01:19 AM
Posts: 8,902 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Run cup pushrod on a roller cam motor and it will not live.
Well here's a dilemma ... if you don't run a cup and you don't use pushrod oiling, then there is no way to effectively lube that point. With a cup, gravity takes care of it.
