stupid question/heater hoses #85857
07/08/08 03:50 PM
07/08/08 03:50 PM
Anonymous OP
Anonymous OP
can you put the heater hoses on wrong as far as which water pump port to which heater core outlet/inlet?
Re: stupid question/heater hoses #85858
07/08/08 04:05 PM
07/08/08 04:05 PM
scratchnfotraction Offline
IMO,no
water will flow both ways
now... it has been said it needs to go a certain way to get it to heat properly
I would say it hottest by the thermostat and the pump is sucking cooler water from the rad
Re: stupid question/heater hoses [Re: scratchnfotraction] #85859
07/08/08 04:07 PM
07/08/08 04:07 PM
Andrewh Offline
Andrewh  Offline
some valves care which direction the flow goes, so that might be an issue, but otherwise I agree.
Re: stupid question/heater hoses [Re: Andrewh] #85860
07/08/08 04:26 PM
07/08/08 04:26 PM
Anonymous OP
Anonymous OP
no valve on the car, just thought I may have the hoses backward because I still cant get the car to run as cool as I think it should.
Re: stupid question/heater hoses #85861
07/08/08 04:28 PM
07/08/08 04:28 PM
Andrewh Offline
Andrewh  Offline
That shouldn't affect cooling at all.
Re: stupid question/heater hoses [Re: Andrewh] #85862
07/08/08 04:53 PM
07/08/08 04:53 PM
Anonymous OP
Anonymous OP
thanks.
Re: stupid question/heater hoses [Re: Andrewh] #85863
07/08/08 04:54 PM
07/08/08 04:54 PM
what temp is it running?
is it sucking a hose flat?
feel the rad to see if there is any cold spots,that would be a clog in the rad
what kind of fan and shroud?
got the right pulley with the right pump?
A/C or no?
condenser in front of the rad?
Re: stupid question/heater hoses [Re: scratchnfotraction] #85864
07/08/08 05:19 PM
07/08/08 05:19 PM
Anonymous OP
Anonymous OP
past midway on the stock gauge, will be hooking a manual autometer up this week.
hose not sucking shut that I can tell.
no cold spots anywhere, everythings hot!
new mp clutch fan and new mp shroud with new 26" radiator.
not sure what pump I have but all the pulleys are new repros from bouchillon for my application.
no a.c. and nothing in front of the radiator.
Re: stupid question/heater hoses #85865
07/08/08 05:49 PM
07/08/08 05:49 PM
what is it ?
checked the timming
carb leaned out
what t stat ya runnin?
5 blade fan?
stick a candy thermo in the rad while hot with cap off.compare to stock and your auto gauge
what kind of weather ya have latly?
when is it runnin hot? idling,at speed>
stall verter with no aux cooler?
Re: stupid question/heater hoses [Re: scratchnfotraction] #85866
07/08/08 06:21 PM
07/08/08 06:21 PM
Anonymous OP
Anonymous OP
69 roadrunner 383 auto new everything.
timing 15 initial 35 total.
holley 3310 jetted from 70's to 76's
180 stat with a 1/8" hole drilled in it.
5 blade mp fan.
cool weather when I first got it going now its in the 90's, car runs the same either way.
warms up fast and stays there no matter how you drive.
175k mp converter with an aux trans cooler.
Re: stupid question/heater hoses #85867
07/08/08 08:18 PM
07/08/08 08:18 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
unless they are sized different (that trumps all), here is how I figure they should be installed.
The hose that water flows out of should be connected to the bottom of the core. This will purge the air better and easier. Also after the flow stops, it allows any debris to drop to the bottom. If you have it the other way, the stuff is forced by gravity and flow into the tubes.
Re: stupid question/heater hoses #85868
07/09/08 08:05 AM
07/09/08 08:05 AM
I would check the water temp with a thermo to get an acurate reading
stock gauges are
my small block runs around 190 with a 180 on hot days and never drops
I just have removed the guts of the stat and used the ring as a restricter and drop it a bit...now it only goes to the 160-170 no matter what
put a spring in the bottom hose to make sure its not sucking flat and try it with a resricter in it maybe
maybe,its where its gonna ride at
