Re: B1 originals
[Re: Brian Hafliger]
#858280
11/20/10 12:22 AM
11/20/10 12:22 AM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Happy Birthday Brian.. and very nice write up on your work.. I've read it before and got some valuable info from it..
The only numbers I saw were these.. Lift Int. Ex. .200 139 102 .300 205 145 .400 267 183 .500 322 218 .600 358 242 .700 381 258 .800 387 268
and I assumed these were after you've done some work, but before you did anything major.. Should I use these numbers to reference an ootb set?
Re: B1 originals
[Re: Jeepmon]
#858284
11/20/10 07:00 AM
11/20/10 07:00 AM
Posts: 716 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I guess it depends on what you mean by OOTB. When I received mine OOTB they had all kinds of casting flash and were kind of ruff. It took about 2 hours to get everything smoothed out. I think Brodix claim is made on a little bit of cleanup work being done.
Joe
Without Data, you’re just another guy with an opinion.
Re: B1 originals
[Re: sr4440]
#858285
11/20/10 08:34 AM
11/20/10 08:34 AM
Posts: 855 Brisbane Australia
572B1
Brisbane Australia
Joe
![](/ubbthreads/images/graemlins/iagree.gif)
Re: B1 originals
[Re: Jeepmon]
#858288
11/21/10 03:29 AM
11/21/10 03:29 AM
Posts: 43,336 Bend,OR USA
Cab_Burge
Don, Koffels usually has a Xmas special starting after 12-01 each year. I bought thier complete package(complete heads minus the springs, keepers and retainers), valley cover, rocker covers, rocker assemblys, intake and gaskets, every thing you need for the top of the motor except a distributor ![](/ubbthreads/images/graemlins/thumbs.gif) ) several yaers ago duriing the special ![](/ubbthreads/images/graemlins/thumbs.gif) I had Koffels port them, they flow 470 CFM at .700, .800 and more at .900 ![](/ubbthreads/images/graemlins/shock.gif) ![](/ubbthreads/images/graemlins/boogie.gif) Now if the economy will pick up some so I can afford to finish buying the rest of the parts to make a new World block 541 or 572 motor I'll be a happy camper ![](/ubbthreads/images/graemlins/devil.gif)
Re: B1 originals
[Re: Cab_Burge]
#858289
11/21/10 03:43 AM
11/21/10 03:43 AM
Posts: 791 Bama
Randy..
Bama
470cfm.. ![](/ubbthreads/images/graemlins/shock.gif) .maybe i let them do mine.
Re: B1 originals
[Re: Cab_Burge]
#858290
11/21/10 05:40 AM
11/21/10 05:40 AM
572B1
Brisbane Australia
Don, Koffels usually has a Xmas special starting after 12-01 each year. I bought thier complete package(complete heads minus the springs, keepers and retainers), valley cover, rocker covers, rocker assemblys, intake and gaskets, every thing you need for the top of the motor except a distributor ) several yaers ago duriing the special I had Koffels port them, they flow 470 CFM at .700, .800 and more at .900 ![](/ubbthreads/images/graemlins/shock.gif) Now if the economy will pick up some so I can afford to finish buying the rest of the parts to make a new World block 541 or 572 motor I'll be a happy camper
Koffels ported my heads. stage 2 port 402cfm @ .800 Cab are you using the pso or mc version?
Re: B1 originals
[Re: pittsburghracer]
#858292
11/21/10 11:59 AM
11/21/10 11:59 AM
Posts: 573 PA
68CudaB1
PA
I am sorry, I like Koffel's, but man their numbers are outrageous. It kind of makes them look silly. NO B1 Originals or M/C's are gonna go 470cfm. We took our M/C's to another flow bench and there was definately a difference in flow benches....Koffel's bench 468, Jensen's bench 443. I do want to say though, the heads made power and we ran w/ the top dogs on most days ![](/ubbthreads/images/graemlins/thumbs.gif)
