WHO USES OIL HEATERS
#858106
11/19/10 06:31 PM
11/19/10 06:31 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I have an in pan Moroso unit. what amount or degrees should I expect it to raise my oil temp to show. Do you leave it on any extended length of time. Can you burn or hurt the oil in any way. I have a in pan gague but it starts at too high a reading 140 which I never gave a thought to when I bought it, next oil change it will be swapped to a zero start
home of the Sox and Martin Hemi Duster
Re: WHO USES OIL HEATERS
[Re: HEMIFRED]
#858107
11/19/10 06:51 PM
11/19/10 06:51 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
One I had in the digger Fred I just left on several hours before I raced. I wouldnt leave it on for days at a time LOL I left it on first time to see how hot the oil would get. I betting 4-5 hours easy. This was a Charlies Custom pan BTW. I dont see how it could get hot enough to hurt the oil even if left on untill it burnt out. Im pretty sure they have a fail safe. ![](/ubbthreads/images/graemlins/wave.gif)
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: HEMIFRED]
#858108
11/19/10 06:54 PM
11/19/10 06:54 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
I've used one for 10 years. It probably won't get 140 without making a pass or warming it up manually. But I plug mine in a 1/2 hour before running in the pits. It will usually get about 10-15* lower than water temp after making a pass. I'm aluminum rods now. Steel rods make more oil heat on my stuff.
[Re: camastomcat]
#858109
11/19/10 07:29 PM
11/19/10 07:29 PM
HEMIFRED
SOUTH JERSEY
I just got a converter to use battery power on the way to the track.that way in an hour I am sure it will be warm enough I might even wrap the accusump
