Page 2 of 3 1 2 3
Re: Progress pics on my fuel system [Re: formula S] #858082
11/25/10 01:49 AM
11/25/10 01:49 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Something just came to mind, a friend of mine used one of those A1000 fuel pumps with methanol and then later after the pump locked up, he found out that it was not compatible with methanol but maybe its ok to use with E-85
Re: Progress pics on my fuel system [Re: formula S] #858083
11/25/10 03:21 AM
11/25/10 03:21 AM
QLD Australia
Keith Black® Offline OP
QLD Australia
thanks, yep I checked with Aeromotive and they said fine with E85. The technical spec's that come with the pumps also says that they're ok with Alcohol, they're then rated for less power as you need more fuel to deliver the same power -hence 2 pumps to be safe.
Pump #1 runs via the speed controller and Pump #2 will be rpm/boost referenced via the ECU when we get that sorted.
looks like stainless will be the go for inspection /pump covers. thanks for your help!!
Darren Beale
Keith Black Racing Engines®
Re: Progress pics on my fuel system [Re: Keith Black®] #858084
11/25/10 07:41 AM
11/25/10 07:41 AM
San Diego
formula S Offline
formula S  Offline
San Diego
I was looking at the Aeromotive web sight and it dose say it is compatible with alchol/ethanol but I did'nt see anything about methanol maybe this is where the problem is on his application. Aeromotive told him to use the A2000 pump and that seemed to work with out locking up. By the way very nice car
Re: Progress pics on my fuel system [Re: Keith Black®] #858085
11/25/10 08:16 AM
11/25/10 08:16 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Very Nice ....
Muffler position ? is it too tight or some clearance issues that you have to run the mufflers off to the side like that ?
I have 3" tail pipe running "next" to my stock tank,,it's tight,,but not hitting,, with the mufflers in front of the axle...you probably have alot more "stuff" under the car that needs clearance compared to a stockish setup ?
would love to see a shot of the underside of the car,,,very cool,,,keep the pics coming...
GREAT job....
Doug
hmmmmmm,,,,i just noticed,,,,do you have FOUR mufflers on the car ? i think i see 2 tucked up under in the stock position ? spill the beans, ,,would like to hear about it,, ,,Doug
Re: Progress pics on my fuel system [Re: 69CHARGERMD] #858086
11/25/10 05:59 PM
11/25/10 05:59 PM
QLD Australia
QLD Australia
hey Doug., yep 4 mufflers ..just trying to make it as quiet as I can (no expectations though )
there is poofteenth of nothing in the way of space under the car, filled with parts. simply amazing, the bigger the car the bigger the stuff you use to fill it up. Plus I've lowered the car 2 ~ 2-1/2in front & back.
I freed up a bit of space with no leafsprings, and really liked the idea of having mufflers up in those recesses, with the tailpipes just angling down. sticking with the theme I want in that the engineering must be tight and "almost" look factory.
In final stages now, mocking everything up before underbody coatings, component coatings , paint etc. although we still have a little engine compartment work to do..
Exhaust is 3-1/2 all the way through with V-clamps and sections made up. here's some more pics..if you're interested in the exhaust..
PS: thanks again to all Moparts members for their inspiration, this has been a HUGE project.
Darren Beale
Re: Progress pics on my fuel system [Re: Keith Black®] #858087
11/25/10 06:00 PM
11/25/10 06:00 PM
QLD Australia
QLD Australia
front..
Darren Beale
Re: Progress pics on my fuel system [Re: Keith Black®] #858088
11/25/10 06:01 PM
11/25/10 06:01 PM
QLD Australia
QLD Australia
to rear..
Darren Beale
Re: Progress pics on my fuel system [Re: Keith Black®] #858089
11/25/10 06:03 PM
11/25/10 06:03 PM
QLD Australia
QLD Australia
rear muffler(s) mounted:
Darren Beale
Re: Progress pics on my fuel system [Re: Keith Black®] #858090
11/25/10 08:33 PM
11/25/10 08:33 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
That car ROCKS,,,,,thanks for the pics....
Re: Progress pics on my fuel system [Re: Keith Black®] #858091
11/25/10 09:00 PM
11/25/10 09:00 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Just my on the stainless steel bolts.
I am not a real fan of stainless bolts, simply due to the fact, if they are dropped in a hard to access area(like maybe into the fuel tank, engine,etc) a magnet will not pick them up for you. DAMHIK!!! I realize they don't rust, corrode as much, etc. Maybe I have just been too 'fumble fingered' too many times.
If you like drag racing, support your local track.
Re: Progress pics on my fuel system [Re: CHAPPER] #858092
11/26/10 02:12 AM
11/26/10 02:12 AM
QLD Australia
QLD Australia
thanks for your help, I will probably run with the stainless bolts at this stage. they can't fall in as the cover plates must be in place before the bolts go in (famous last words I bet).
I need to make up the in-tank wiring too ... does anyone know if std 10 gauge electrical PVC wire is resistant to E85 ..?
Darren Beale
Re: Progress pics on my fuel system [Re: Keith Black®] #858093
05/09/11 06:11 AM
05/09/11 06:11 AM
QLD Australia
QLD Australia
thought I would put up some more pic's for those that are interested (I know it's been a while just been busy) as the fuel system comes together.
The standard tank is baffled internally with a centre sump & one-way anodised check-valves. There's an access plate in the centre of the top of the tank, and another at the front top where the access plate has the two pumps& filters suspended to it's underside.
Here's the dual pump setup sitting in place (access plate removed):
Darren Beale
Re: Progress pics on my fuel system [Re: Keith Black®] #858094
05/09/11 06:13 AM
05/09/11 06:13 AM
QLD Australia
QLD Australia
pump & filter assembly (bolts to underside of access plate):
Darren Beale
Re: Progress pics on my fuel system [Re: Keith Black®] #858095
05/09/11 06:15 AM
05/09/11 06:15 AM
QLD Australia
QLD Australia
inside front of tank with pumps/filter assembly/plate lifted off:
Darren Beale
Re: Progress pics on my fuel system [Re: Keith Black®] #858096
05/09/11 06:16 AM
05/09/11 06:16 AM
QLD Australia
QLD Australia
Another shot of pump/filter assembly out of tank:
Darren Beale
Re: Progress pics on my fuel system [Re: Keith Black®] #858097
05/09/11 06:24 AM
05/09/11 06:24 AM
QLD Australia
QLD Australia
we will be able to remove the access plates for any servicing as we modify the boot floor to have an access panel.
Also, I am adding two additional tanks for sufficient capacity. They will fit inside the rear quarters and extent as far toward the centre of the trunk as the trunk lid lip. I'm adding another gas cap to the RH quarter. Each gas cap will fill each side tank, which will then feed into the main tank. Each quarter tank will be fabricated from aluminium with internal bladders (made by ATL in NJ). Vents from all 3 tanks will run into charcoal canister to stop any fumes.
Engine will run on both E85 & ordinary petrol. primary pump is speed controlled and second is staged.
Darren Beale
Re: Progress pics on my fuel system [Re: Keith Black®] #858098
05/09/11 08:31 PM
05/09/11 08:31 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
First class all the way. Are you going to powder coat or paint the tank? I'm at the fuel system stage on my 69 Charger as well, however mine won't be near as well thought out and planned as yours. Please keep us updated!
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Progress pics on my fuel system [Re: Keith Black®] #858099
05/09/11 09:15 PM
05/09/11 09:15 PM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
How is E85 with raw aluminium? I know methanol would eat into it.
Looks great though!
Alan Jones
Re: Progress pics on my fuel system [Re: LA360] #858100
05/09/11 10:47 PM
05/09/11 10:47 PM
QLD Australia
QLD Australia
thanks!
the tank is std, everything aluminium is being anodised.
the 2 other tanks will have custom made internal bladders (safety requirement here in Australia for engineer certification/registration).
Darren Beale
Re: Progress pics on my fuel system [Re: formula S] #858101
05/10/11 10:41 PM
05/10/11 10:41 PM
Mo.
racerx Offline
racerx  Offline
Mo.
This may be a Dumb ? but i'll ask anyway What's the differance between alchol/methanol?
Page 2 of 3 1 2 3
