Re: Reverse manual Valve body vs Forward Shifting VB? [Re: BradH] #857971
11/20/10 09:02 PM
11/20/10 09:02 PM
K
kielbasa Offline
kielbasa  Offline
K
I told him hp level will be between 5 and 600......he said he could do it, but not recommend it.
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: kielbasa] #857972
11/21/10 02:12 PM
11/21/10 02:12 PM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
I've run both on the street and strip. I've lost races with the forward-bumping into neutral from the 2nd to 3rd shift is way too easy. I've also been told that the reverse is easier on the tranny if you do a lot of street miles.
Tom
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: Mopar_Mike] #857973
11/21/10 08:36 PM
11/21/10 08:36 PM
Canada north shore lake Ontari...
ross Offline
ross  Offline
I too like the foreward shift pattern as it mimicks the factory pattern. I am old and have been afaid of putting the tranny into a lower gear at the top end. I use the turbo action fmvb but I believe it cannot be made without the low band apply and for the serious racer this would slow them down a bit hence the populatity of the mrvb.
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: Mopar_Mike] #857974
11/22/10 10:06 AM
11/22/10 10:06 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Why is it that everyone who builds race ready transmissions will only do it with a reverse shift valve body. Personally I prefer a forward shifting manual valve body, seems more natural.. Whats the big difference?
It is more than a matter of preference. This is because the forward pattern uses the shift valves to command the shifts by short circuiting the governor passage. The reverse pattern shifts directly from the manual valve, eliminating the shift valves, giving a better quality gear shift. Shifting through the 1-2, 2-3 shift valves can limit the line pressure because they influence shift timing.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: kielbasa] #857975
11/22/10 11:25 AM
11/22/10 11:25 AM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
i REALLY wanted to keep my slapstick, but trans builder talked me out of fmvb (since i'll have considerably more horsepower than stock) because he told me rmvb allows higher line pressure (or something to that effect) than fmvb......i will install the Duncan shift-r-gate, so at least i can still keep my slapstick though, haven't tried it out yet though.
This is confusing, because no matter where 1st is on the shifter it still in the same spot in the transmission. and i dont see how horsepower would make a difference in shift forward or backwards.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: kissmyaspen] #857976
11/22/10 02:41 PM
11/22/10 02:41 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Did you see this ?
Allan G.
The more power an engine makes more line pressure is needed to hold the clutches from slipping.
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: JohnRR] #857977
11/22/10 06:43 PM
11/22/10 06:43 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
The regulator valve is what controls the pressure.
79 Dodge Aspen
67 Satellite NSS/E
11.83 @ 110
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: JohnRR] #857978
11/22/10 06:44 PM
11/22/10 06:44 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Mine is reverse and I wish it was regular pattern sometimes...
like the last time I doinked it back into 2nd after a pass at the track because I had a habit of shifting to neutral after the traps. oopsie.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: kissmyaspen] #857979
11/22/10 09:40 PM
11/22/10 09:40 PM
Allan G.
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: JohnRR] #857980
11/22/10 10:34 PM
11/22/10 10:34 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Hmmmm....... Ok so it is not recommended for higher torque and Hp levels.
My engine should make north of 700 hp and more tq. I have a forward shift pattern. My car is fairly light weight (2500 lbs approx.) and will be a street strip version.
What should I expect to be the down side of this shift pattern? Trans failure, or just not perform to the highest level?
Would the lighter car make the lower pressure less important?
I thougth I was about finished buying stuff and could finish this car. Now my tranny and shifter are in question!
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: Hemi Allstate] #857981
11/22/10 10:44 PM
11/22/10 10:44 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I'm using a forward pattern manual VB with my 572 Hemi. I expect to see similar HP levels but in a heavy, 4000 pound car. So far its been good BUT I haven't leaned on it yet and never raced it as of yet.
For your application, you may get away with it since you are much lighter. If it will see mostly street duty, then chances are better.
Like everything else, you won't know unitl you try.
Allan G.
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: turbobitt] #857982
11/22/10 11:08 PM
11/22/10 11:08 PM
Mt. Eden Ky.
Mt. Eden Ky.
Allan G.
Allan, I am using a 572 Hemi as well. I may just have to try it. I know that I should do some other upgrades for safety.
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: BradH] #857983
11/22/10 11:50 PM
11/22/10 11:50 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i REALLY wanted to keep my slapstick, but trans builder talked me out of fmvb (since i'll have considerably more horsepower than stock)...
How much HP will that be? Just curious since I use a Turbo Action FMVB w/ about 600 HP and have no problems running in the 10s.
over 700hp here with foward manual vb and a slap stick and never a problem. i personally think the slap stick is one of the best shifters there is. i made a reverse lockout for mine and whenever i try an aftermaret shifter i always hate it
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: JohnRR] #857984
11/23/10 11:52 AM
11/23/10 11:52 AM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
Allan G.
Now i can see this happening more with a shift kit but not with a manual valve body. evrything you read in the transmission books says that its a personal prference to using a forward or reverse vb. and the only difference u have in line pressure with manual valve bodies is if it has a brake in it or not. the brake has more pressure.
79 Dodge Aspen
67 Satellite NSS/E
11.83 @ 110
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: sixpackgut] #857985
11/23/10 12:14 PM
11/23/10 12:14 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
over 700hp here with foward manual vb and a slap stick and never a problem...
I still use the SlapStik shifter in my Challenger, too.
FWIW, I called up Turbo Action to ask them about which of their FMVB to use, the one w/ LBA or the one w/o. For my performance level, etc., the tech rep said to go w/ the "Race" (no LBA) version, since it would be quicker than the "Pro Street" (LBA) model, even though mine is a street/strip application.
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: BradH] #857986
11/23/10 01:36 PM
11/23/10 01:36 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
thats why your so fast. i have the LBA version.
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: sixpackgut] #2855989
12/06/20 12:50 PM
12/06/20 12:50 PM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Hi Moparts,
One of the best threads I've read in years!
Forwards up against reverse pattern...
In my race car I used a reverse pattern (no steel drum) with a good quality shifter, worked GREAT as Tony (tiger) would say.
But now I want to run the stock slapstick in my 71 GTX (street-stripper) so I'm gonna go 'full manual' forward pattern and a STEEL-DRUM! drive
What could go wrong lol... fan
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: Mopar_Mike] #2856359
12/07/20 01:39 AM
12/07/20 01:39 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
let me know haw the shift-r-gate works for you.
I installed one in the '71 Charger, and the button on the shifter does not seem right, and the shifter feels stiff and notchy, but it does work.
Re: Reverse manual Valve body vs Forward Shifting VB? [Re: 451Mopar] #2856571
12/07/20 02:21 PM
12/07/20 02:21 PM
moparx Offline
moparx  Offline
i have a duncan gate plate, but i haven't installed it yet.
is that what you used on your charger ?
i have an old rusted up slapstick mechanism i thought about tearing apart and possibly using parts from it, or using the parts to get an idea how the mechanism functions, then fabbing my own to turn a 69 B-body shifter into a slap stick.
beer
