Re: Reverse manual Valve body vs Forward Shifting VB?
[Re: kielbasa]
#857972
11/21/10 02:12 PM
11/21/10 02:12 PM
Posts: 226 lino lakes,MN
onebaddakota
lino lakes,MN
I've run both on the street and strip. I've lost races with the forward-bumping into neutral from the 2nd to 3rd shift is way too easy. I've also been told that the reverse is easier on the tranny if you do a lot of street miles. Tom
10.56 at 125.6, with a 1.43 60 ft.
E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
[Re: kielbasa]
#857975
11/22/10 11:25 AM
11/22/10 11:25 AM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
i REALLY wanted to keep my slapstick, but trans builder talked me out of fmvb (since i'll have considerably more horsepower than stock) because he told me rmvb allows higher line pressure (or something to that effect) than fmvb......i will install the Duncan shift-r-gate, so at least i can still keep my slapstick though, haven't tried it out yet though.
This is confusing, because no matter where 1st is on the shifter it still in the same spot in the transmission. and i dont see how horsepower would make a difference in shift forward or backwards.
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: kissmyaspen]
#857976
11/22/10 02:41 PM
11/22/10 02:41 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
Did you see this ?
This is because the forward pattern uses the shift valves to command the shifts by short circuiting the governor passage. The reverse pattern shifts directly from the manual valve, eliminating the shift valves, giving a better quality gear shift. Shifting through the 1-2, 2-3 shift valves can limit the line pressure because they influence shift timing. Allan G.
The more power an engine makes more line pressure is needed to hold the clutches from slipping.
[Re: JohnRR]
#857977
11/22/10 06:43 PM
11/22/10 06:43 PM
kissmyaspen
Newark,Ohio
The regulator valve is what controls the pressure.
[Re: JohnRR]
#857978
11/22/10 06:44 PM
11/22/10 06:44 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Mine is reverse and I wish it was regular pattern sometimes...
like the last time I doinked it back into 2nd after a pass at the track because I had a habit of shifting to neutral after the traps. oopsie.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: kissmyaspen]
#857979
11/22/10 09:40 PM
11/22/10 09:40 PM
JohnRR
A gulag near you.
[Re: JohnRR]
#857980
11/22/10 10:34 PM
11/22/10 10:34 PM
Posts: 2,686 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Hmmmm....... Ok so it is not recommended for higher torque and Hp levels. My engine should make north of 700 hp and more tq. I have a forward shift pattern. My car is fairly light weight (2500 lbs approx.) and will be a street strip version. What should I expect to be the down side of this shift pattern? Trans failure, or just not perform to the highest level? Would the lighter car make the lower pressure less important? I thougth I was about finished buying stuff and could finish this car. Now my tranny and shifter are in question!
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: turbobitt]
#857982
11/22/10 11:08 PM
11/22/10 11:08 PM
Hemi Allstate
Mt. Eden Ky.
I'm using a forward pattern manual VB with my 572 Hemi. I expect to see similar HP levels but in a heavy, 4000 pound car. So far its been good BUT I haven't leaned on it yet and never raced it as of yet. For your application, you may get away with it since you are much lighter. If it will see mostly street duty, then chances are better. Like everything else, you won't know unitl you try. Allan G.
Allan, I am using a 572 Hemi as well. I may just have to try it. I know that I should do some other upgrades for safety. Thanks, Mark
[Re: sixpackgut]
#857985
11/23/10 12:14 PM
11/23/10 12:14 PM
BradH
i REALLY wanted to keep my slapstick, but trans builder talked me out of fmvb (since i'll have considerably more horsepower than stock)...
How much HP will that be? Just curious since I use a Turbo Action FMVB w/ about 600 HP and have no problems running in the 10s.
over 700hp here with foward manual vb and a slap stick and never a problem...
I still use the SlapStik shifter in my Challenger, too.
FWIW, I called up Turbo Action to ask them about which of their FMVB to use, the one w/ LBA or the one w/o. For my performance level, etc., the tech rep said to go w/ the "Race" (no LBA) version, since it would be quicker than the "Pro Street" (LBA) model, even though mine is a street/strip application.
[Re: BradH]
#857986
11/23/10 01:36 PM
11/23/10 01:36 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
thats why your so fast. i have the LBA version.
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2855989
12/06/20 12:50 PM
12/06/20 12:50 PM
Posts: 349 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Hi Moparts, One of the best threads I've read in years! Forwards up against reverse pattern... In my race car I used a reverse pattern (no steel drum) with a good quality shifter, worked GREAT as Tony (tiger) would say. But now I want to run the stock slapstick in my 71 GTX (street-stripper) so I'm gonna go 'full manual' forward pattern and a STEEL-DRUM! What could go wrong lol...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: 451Mopar]
#2856571
12/07/20 02:21 PM
12/07/20 02:21 PM
Posts: 20,272 north of coder
moparx
i have a duncan gate plate, but i haven't installed it yet. is that what you used on your charger ? i have an old rusted up slapstick mechanism i thought about tearing apart and possibly using parts from it, or using the parts to get an idea how the mechanism functions, then fabbing my own to turn a 69 B-body shifter into a slap stick.
