what are some reason why truck still starts hard #857931
11/19/10 04:07 PM
11/19/10 04:07 PM
ME
79machocharger Offline OP
ME
78 ramcharger and it's starting hard for my step father. We had the edelbrock 600 carb all rebuilt, added new high torque starter, all new plugs, wires, and it's still starting hard. It has a manual choke on it and you have to let the truck crank over quite a few time before it will start. Any ideas what causeing the hard starting. It runs great once it's started.
Thanks for any help
Re: what are some reason why truck still starts hard [Re: 79machocharger] #857932
11/19/10 04:36 PM
11/19/10 04:36 PM
Bowling Green, Ky
TheDodgeBoys Offline
Bowling Green, Ky
Here are a few things to check.
1. make sure you have a minimum 4-5 psi of fuel pressure.
2. when the carb was rebuilt, do you know if they installed a new excellerator pump in the carb as well as a new pump spring? This will cause serious issues with hard starting. This not only brings fuel into the carb it helps maintain it in the bowl. If the pump is wore out, or if the diagphram is bad, it will leak down causing a hard starting condition.
I hope this helps.
1968 NSS/AA "HEMI" DODGE DART 1970 "452" E-85 PLYMOUTH DUSTER 1987 "318" RAM D100 1983 "318" RAMCHARGER (408 SOON) RACER'S FOR CHRIST CHAPLAIN NHRA DIVISION 3 "LAND OF THE WINNERS" ....AND ON THE 8TH DAY, GOD CREATED MOPARS
Re: what are some reason why truck still starts hard [Re: TheDodgeBoys] #857933
11/19/10 04:58 PM
11/19/10 04:58 PM
ME
ME
That's great help, I'll go out and get a fuel pressure qauge for it tonight and make sure. I'll call the guy that rebuilt the carb and ask if he changed those out when he rebuilt it.
Re: what are some reason why truck still starts hard [Re: 79machocharger] #857934
11/19/10 06:37 PM
11/19/10 06:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What's the timing set at?
Re: what are some reason why truck still starts hard [Re: 79machocharger] #857935
11/19/10 07:07 PM
11/19/10 07:07 PM
Milano, Italia
FK5 Offline
FK5  Offline
Milano, Italia
I'd check the fuel line and filter too. Leaky/weepy fuel lines have caused me all sorts of problems.
Re: what are some reason why truck still starts hard [Re: 79machocharger] #857936
11/19/10 09:40 PM
11/19/10 09:40 PM
Adventurer_Sport Offline
My totally restored '73 was hard starting, and it continued to get worse until one day at the barber shop, it wouldn't start. It turned over normally, but wouldn't fire.
A guy in a diesel Ram with dual batteries gave me a jump, but it took a whole lot of cranking before it finally fired. Though the rebuilt one on the truck was nearly new, I decided to try changing starters. I installed a new mini-starter from a Dakota and it fired immediately. A year later, it fires the first time, and every time I touch the starter. The best $120 investment I ever made.
Your results may vary.......
Re: what are some reason why truck still starts hard [Re: Adventurer_Sport] #857937
11/19/10 10:14 PM
11/19/10 10:14 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
is the fel boiling in the carb when it shuts off and evaporates...then yo have to fill the bowl then it will start...used to happen on my eddie 750 all the time...so I bought a holley and its fixed...
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: what are some reason why truck still starts hard [Re: pnypwr] #857938
11/19/10 10:26 PM
11/19/10 10:26 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Never did care for the manual choke carbs very much. They start when it's warm, but not so easily when it's cold and you actually need it.
Make sure the choke air door is not fully closed. It needs to be open about the thickness of a paper clip.
Re: what are some reason why truck still starts hard [Re: pnypwr] #857939
11/19/10 10:26 PM
11/19/10 10:26 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I agree with the possible boiling...when u go to start it, before u do,look down the carb and give it few pumps with the lever and see if fuel is going in or it just pumps a little and goes dry...u have to start there...if it is, add a spacer to lift it off the mani...to stop the heat from boiling the fuel bowl...
Re: what are some reason why truck still starts hard [Re: 79machocharger] #857940
11/19/10 10:35 PM
11/19/10 10:35 PM
next time you go to start it 1st take off the air cleaner, hold the choke where it is & pump the throttle several times and see what you have for AP shot (amt/duration) then let go of the choke & see where it closes at. A ballpark figure on auto choke setting, it should be lightly closed @70F.
Re: what are some reason why truck still starts hard [Re: RapidRobert] #857941
11/19/10 11:22 PM
11/19/10 11:22 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
The AFB's on my Hemi dry out in no time. That's my guess as to whats happening here.
Sheldon
Re: what are some reason why truck still starts hard [Re: RUNCHARGER] #857942
11/20/10 12:01 AM
11/20/10 12:01 AM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
All too common problem with Edelbrock carbs. Best fix is buy a Holley.
Re: what are some reason why truck still starts hard [Re: Hemidavey] #857943
11/20/10 09:54 AM
11/20/10 09:54 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Very common with an eddy or a carter. Bowls evaporate or dry out after sitting for a while.
Re: what are some reason why truck still starts hard [Re: 79machocharger] #857944
11/20/10 11:07 AM
11/20/10 11:07 AM
Maine
P
Pkeel Offline
Pkeel  Offline
P
Maine
I was having major problems with a 318 and hard starting. Nitrous suggested carbon buildup on the intake manifold. Removed cleaned and fixed. I have a thermoquad on it.
I spent all kinds of money on carb rebuild, choke repairs, timing, coil etc. The carbon build up was not allowing the exhaust to flow properly.
Re: what are some reason why truck still starts hard [Re: Pkeel] #857945
11/20/10 12:11 PM
11/20/10 12:11 PM
I'm wondering how the carbon buildup was causing it to start hard? I could see it causing poor warmup if the head crossover is plugged. My heat riser passages are plugged (stock dd 318) which is killing my gas mileage but it does start flawlessly (eddie 1406 600). The more info the better as I'm lost on this particular prob & if it wasn't so cold I'd ride my bike, it's that bad .
Re: what are some reason why truck still starts hard [Re: RapidRobert] #857946
11/20/10 12:44 PM
11/20/10 12:44 PM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
first thing is to trouble shoot the problem and determine if the hard starting is caused by no spark, weak spark, no fuel, or to much fuel.
Re: what are some reason why truck still starts hard [Re: SixDRacing] #857947
11/20/10 12:51 PM
11/20/10 12:51 PM
That's it!
