master cylinders- understanding date codes 101 #857507
11/18/10 11:02 PM
11/18/10 11:02 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ok, I have this master cylinder -= cast # 3461187
On the brass bail wire tag is
1176
and below that is 3659B
the there is PWR stamped on the outer edge
Is the 1176 a date of 176th day of 1971 ?
and the 3659B a vender code maybe
It's off a 1971 charger that was power brakes if it matters
Re: master cylinders- understanding date codes 101 [Re: gtx6970] #857508
11/18/10 11:16 PM
11/18/10 11:16 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
1176 is the last 4 numbers of the Chrysler part number; 3461176
The other number is some sort of vendor number.
Those tags didn't appear until appearing on some new design master cylinders in 1971.
The only one I have here currently has the date code stamped in the nose of the casting.
To confuse matters, on disc brake master cylinders from '67-'69, they used a similar tag but it showed only the date code.
I don't believe any 1970's came with any sort of tags, their datecodes were stamped in the fender side of the casting.
This concludes disc brake Mopar master cylinder date coding 101, your diploma is in the mail.
Re: master cylinders- understanding date codes 101 [Re: Mastershake340] #857509
11/19/10 01:29 PM
11/19/10 01:29 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Odd - I have three 187 master cylinders and all three of them are slightly different from a casting stand point.
I'll check date codes tonight now that I know where they are ... THANKS
Re: master cylinders- understanding date codes 101 [Re: Morty426] #857510
11/19/10 07:12 PM
11/19/10 07:12 PM
Crook County, ILL
Crook County, ILL
I've seen 3461187 master cylinders with different casting numbers. The main difference I have noticed is the outlet bosses protrude different lengths.
Re: master cylinders- understanding date codes 101 [Re: Mastershake340] #857511
11/19/10 07:21 PM
11/19/10 07:21 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I've got the part number casted into the part and casted out of the part (raised numbers) there are also some other features
Re: master cylinders- understanding date codes 101 [Re: Morty426] #857512
11/19/10 10:37 PM
11/19/10 10:37 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Brad, I've got a 3461187 m/c with a brass tag on the bail wire with 0111 as first #, thought this was a date code too, following your info that it was the last set of #'s of a part #, I looked in my parts book and don't see these as the last #'s on any listed - any idea - guess it could have migrated there over the years too from another master using the same bail wire on a rebuild...thanks, Joe
Re: master cylinders- understanding date codes 101 [Re: shakerjoe] #857513
11/20/10 02:43 AM
11/20/10 02:43 AM
Crook County, ILL
Crook County, ILL
That's interesting, I never have seen a tag like that.
The latest date code tag I have seen is from spring of 1969. I have an NOS disc brake master cylinder with a July '69 datecode stamped in the side.
Take a close look at your casting, see if you can find any datecode stamped in it, either on the fender side or the nose of the casting would be the place to look.
Re: master cylinders- understanding date codes 101 [Re: Mastershake340] #857514
11/20/10 10:23 PM
11/20/10 10:23 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Nothing on the side Brad, on the nose is a 4 then space, then 51 - in the space I thought there was a faint 2 - but I think it's a space and just the casting of the metal/shadowing - what would the 4 51 spell out as - thanks - Joe
Re: master cylinders- understanding date codes 101 [Re: shakerjoe] #857515
11/22/10 03:16 PM
11/22/10 03:16 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I don't see anything on the nose or the side of the casting of the one I have
Re: master cylinders- understanding date codes 101 [Re: gtx6970] #857516
11/22/10 03:17 PM
11/22/10 03:17 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
casting #
Re: master cylinders- understanding date codes 101 [Re: gtx6970] #857517
11/22/10 03:17 PM
11/22/10 03:17 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
tag in question
Re: master cylinders- understanding date codes 101 [Re: gtx6970] #857518
11/23/10 02:15 PM
11/23/10 02:15 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
What was the correct finish for the bail wire and the top cover for this master?? Im thinking the cyl itself was natural (it was on my orig 26k mile Charger R/T) but the B-Body usually used the midland ross booster that was plated, not painted like the bendix booster on a 71 Challenger. If you have a 71 Challenger with a painted (bendix)booster was the master cyl painted together as an assembely like a 70 e-body ??? Yes I already know a 70 car had a different master.
Re: master cylinders- understanding date codes 101 [Re: THESHAKERPROJECT] #857519
04/25/11 07:39 PM
04/25/11 07:39 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
For 1971 - what color is the cap? Gold Cad?
And what color is the bailing wire? Clear cad?
And the housing is it plated? Black or gray phosphate?
Re: master cylinders- understanding date codes 101 [Re: Morty426] #857520
04/25/11 09:38 PM
04/25/11 09:38 PM
Crook County, ILL
Crook County, ILL
Here is a picture of an NOS one I have, you can see it is all gray phosphate.
The bale wire looks like it has the same coating.
Re: master cylinders- understanding date codes 101 [Re: Mastershake340] #857521
04/25/11 09:40 PM
04/25/11 09:40 PM
Crook County, ILL
Crook County, ILL
Date code
Re: master cylinders- understanding date codes 101 [Re: Mastershake340] #857522
04/25/11 09:48 PM
04/25/11 09:48 PM
Crook County, ILL
Crook County, ILL
Of course on the '71 Challenger I bought last year, someone had painted the master cylinder black.
They probably used the same can of paint to paint the heater blower motor.
A couple more of the many details I need to attend to on this car. Anyone have any recommendations for a rattle can product that is close to the gray phospate coating?
And how about one that is close to the proper silver cad plating for my blower motor?
Re: master cylinders- understanding date codes 101 [Re: Mastershake340] #857523
04/26/11 08:19 AM
04/26/11 08:19 AM
CT
1932chrysler Offline
CT
I used Seymour brand stainless steel paint for blower motor, master cylinder cap & bail
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
