Re: 4 speed disassembly guide
[Re: Theorio1025]
#857130
11/18/10 03:43 PM
11/18/10 03:43 PM
Posts: 4,285 Ohio
64dodge572
Ohio
I have to remove my input shaft to have it cut down, and I was wondering if anyone on here has a 4 speed disassembly guide or some diagrams?
Why do you need to cut down the input?
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: IMGTX]
#857133
11/18/10 05:01 PM
11/18/10 05:01 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Use the adapter bushing you bought, and drill the clearance in the crank. I have done it with the engine assembled without any problems. ![](/ubbthreads/images/graemlins/Twocents.gif) Dan
[Re: 64dodge572]
#857135
11/18/10 06:00 PM
11/18/10 06:00 PM
Posts: 184 Vernon Ct.
bp27
Vernon Ct.
That's what I did
