Wheel Spacer?? #856923
11/18/10 11:32 AM
11/18/10 11:32 AM
Irwin, PA
62BT409 Offline OP
62BT409  Offline OP
Irwin, PA
Is there a manufacture that makes a custom wheel spacer instead of the multi-fit - multi-hole spacer?
Re: Wheel Spacer?? [Re: 62BT409] #856924
11/18/10 12:32 PM
11/18/10 12:32 PM
GA
Boosted Offline
Boosted  Offline
GA
A local machine shop could do this for you.. what is wrong with a multi hole spacer?
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Wheel Spacer?? [Re: Boosted] #856925
11/18/10 12:39 PM
11/18/10 12:39 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No spacer is best, a custom made one is better than the univerisals. I have some 1/4" spacers from Mark Williams Ent that are drilled for 3 bolt circles, that's the same as custom made, IMO. 1/4" is the thickest you should use if you have to.
Re: Wheel Spacer?? [Re: 62BT409] #856926
11/18/10 12:43 PM
11/18/10 12:43 PM
Newfoundland
Crocker Offline
Crocker  Offline
Newfoundland
There are spacers and adaptors. Spacers are just that. Adaptors bolt to the existing studs and have a 2nd set of studs for the wheel.
How thick do you need?
I went with American racing wheels on the barracuda so I needed an adaptor for the front. The better quality ones use 6061-t6 aluminum and grade 8 hardware.
I seem to recall not to use spacers if you need more than 1/4"
Re: Wheel Spacer?? [Re: Challenger 1] #856927
11/18/10 04:17 PM
11/18/10 04:17 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
yes we make custom direct fit, hub centric spacers. ours are made from 6061 aluminum or 1018 steel.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
