old hood into a new trunk floor #856887
11/18/10 10:10 AM
11/18/10 10:10 AM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
i bought a 68 polara hood from the junkyard, seperated it from its skeleton, cut it to fit my 47 desoto. i still need to finish welding it in(ran out of wire yesterday), make a shallower than original spare tire well, put an opening in for the fuel cell and add some supports underneath to hold the weight. buying a hood is much cheaper than buying new sheet metal.
Re: old hood into a new trunk floor [Re: 65rbdodge] #856888
11/18/10 11:22 AM
11/18/10 11:22 AM
GSO.NC
Mstaedt Offline
mopar addict
Mstaedt  Offline
mopar addict
GSO.NC
Nice touch keeping it Mopar
Re: old hood into a new trunk floor [Re: Mstaedt] #856889
11/18/10 10:27 PM
11/18/10 10:27 PM
moparx Offline
moparx  Offline
that's using the ol noodle ! good job !
Re: old hood into a new trunk floor [Re: Mstaedt] #856890
11/18/10 10:31 PM
11/18/10 10:31 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
Nice thing about using something like a hood is its already protected from rusting, except where you ground off the paint to weld it in. Gene
Re: old hood into a new trunk floor [Re: 65rbdodge] #856891
11/20/10 01:57 AM
11/20/10 01:57 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
I like it!
I might have tried using the center piece with the ribs for her pleasure... I mean strength.
Re: old hood into a new trunk floor [Re: FuryUs] #856892
11/20/10 03:59 PM
11/20/10 03:59 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Nice but I would have rolled some beeds in it. Does it flex alot?
Re: old hood into a new trunk floor [Re: 76dodgeboy] #856893
11/21/10 06:15 PM
11/21/10 06:15 PM
n.e. pa.
n.e. pa.
i`ll be welding angle iron across the bottom of it and to the frame. i dont own a bead roller.
Re: old hood into a new trunk floor [Re: 65rbdodge] #856894
11/26/10 04:39 AM
11/26/10 04:39 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
GREAT IDEA
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: old hood into a new trunk floor [Re: fstfish66] #856895
11/29/10 03:37 PM
11/29/10 03:37 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Neat! I look at things the same way!
The sheetmetal I used for the floor in my Model A Ford came from an old dryer I found on the side of the road. I found a steel 1942 penny when I cut it apart. Who knows how many loads of laundry that penny had gone through!
Re: old hood into a new trunk floor [Re: rabid scott] #856896
12/11/10 11:45 PM
12/11/10 11:45 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Nice, I like it.
They say hot rodders are the original recyclers.
I have a 68 Polara that I plan on cutting the top of the rear fenders off and flipping them to use on the opposite side lower portion of my New Ports quarters. Similar crease down the panel just seems inverted from Chrysler to Polara. First I need to practice with the fire knife for awhile. Fun fun fun.
Re: old hood into a new trunk floor [Re: bboogieart] #856897
04/08/11 08:30 PM
04/08/11 08:30 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Sheet metal is sheet metal. Use it!
