Making a Windage Tray out of Aluminum-What do you think
#85619
07/08/08 12:01 AM
07/08/08 12:01 AM
moparAL
I saw a ad for a Aluminum Windage Tray for a Mopar stroker Big Block by a company named Pro Aluminum Products. http://proaluminumproducts.comWhat do you think? Pros and Cons of making a windage tray out of aluminum compared to steel??? Thanks for any input. AL
Re: Aluminum BB Stroker Windage Tray. What do you think?
[Re: moparAL]
#85620
07/08/08 01:18 AM
07/08/08 01:18 AM
Posts: 8,064 Arlington, Texas
earlybee
Arlington, Texas
They/he, Whoever?, ( no address on website) is a patent thief that get by the law because they make cheap, unsafe, knockoff products out of aluminum instead of steel. http://www.deluxealuminumproducts.com/servlet/the-15/new-aluminum-b-dsh-body-drive/Detail Look at all the crap they copy from others! Our board sponsor John Pasemann designed his driveshaft loop first, (then they copied), out of steel which is the only one of the two that is NHRA safe. http://www.uscartool.com/
[Re: moparAL]
#85626
07/08/08 12:31 PM
07/08/08 12:31 PM
earlybee
Arlington, Texas
What do you think? Pros and Cons? Thanks for any input. AL
I see you edited your post from last night to make my opinion of the company seem O/T today. So I,ll edit mine too, Thats the greatest tray ever made because they said it won,t rust and its only $10.00 more than steel!
[Re: JohnRR]
#85627
07/08/08 02:34 PM
07/08/08 02:34 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
But my question was about a aluminum windage tray? Is it a stupid or good idea?????? Any opinions???
why wouldn't it be , it only there to STOP the crank windage
OK ...directly ON-topic ....
It depends on how thick the material is. If it is some thin stuff(like some of the China-mart parts) - it could bend, then get tangled-up in the crank and then wipe-out the motor.
Something like this ... I would use the steel piece.
[Re: dOrk !]
#85628
07/08/08 09:02 PM
07/08/08 09:02 PM
Posts: 667 CA
66Dodge
super gas
super gas
CA
If you think you have a better design in mind than the MP piece or the Milodon piece then go for it. If you're trying to save weight, it's not that significant. If you're trying to save money, it's your time and sweat. Be careful of the thickness of the aluminum. If it's too thin it might crush,warp,deform at the flange when you try to snug up the oil pan bolts. FWIW, the price of the aluminum one seems to be more expensive than the MP or Milodon. In that case, I will stick with steel. Plus the MP one includes 2 oil pan gaskets.
[Re: 66Dodge]
#85629
07/08/08 09:21 PM
07/08/08 09:21 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Unless someone chimes in that is USING one, your just getting a bunch of from people looking at the same pics you are If you wanna be the guinea pig, which is what you will be it sounds like. Let us know what you find out. I have and do run the MP and Milodon trays without issue. I'll recommend them, and continue to use them.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
