Re: Do Part Numbers Translate to Year the Part Was Produced
[Re: TONY_DAGOSTINO]
#855867
11/17/10 02:22 PM
11/17/10 02:22 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Ahhh...Ok....Me dumb....I understand better just re-reading your first post.....too many paint fumes for me today... carry on.......
CHECK OUT MY NEW WEB SITE !
[Re: anlauto]
#855868
11/17/10 02:54 PM
11/17/10 02:54 PM
Posts: 21,534 It's a dry heat
gtx6970
It's a dry heat
one way to look at is the lower the #, the earlier it tends to be in a particular series.Like anything else there are exceptions
as an example pt #'s beginning with say 2200200 tends to be early 60's , where as pt #'s beginning as 2900200 tends to be late in the series in this case the 60's . I've asked several long time Mopar parts dealers and they all seem to agree - there is/was no system.
then in recent years , they tend to use the same part # on an individul part , then just add a 2 letter alphabetical suffix at the end to show supersessions. The original Pt # may be 54009000 , then followed by 54009000AB , AC, AD, AE and so on
[Re: A12]
#855870
11/19/10 10:28 AM
11/19/10 10:28 AM
Posts: 426 Mid-Atlantic
Scatransit
Mid-Atlantic
As I recall, the first number refers to the decade of production of whichever model/platform the part is made for...The second number is the year... For example a part for a 68 Coronet would start with "28XXXX", a 71 would be "31XXXX" etc... Not an expert, just offering...
[oo]======[oo]
[Re: Scatransit]
#855871
11/19/10 11:18 AM
11/19/10 11:18 AM
Posts: 8,162 DELAWARE
TONY_DAGOSTINO
DELAWARE
hi i understand your input but there really wasnt any pattern assigned to part #s + year application
there arent part #s starting with 310xxxx thru 330xxxx for cars,
like i said in my first post, rule of them, not always, ballpark only add 40 to the first 2 numbers
i dont understand how a 2 refers to the 1960s decade, and like i had said earlier, once you hit the 1970s this "formula" doesnt work
i wish it was a predestined formula set up by chrysler, it really would have made iding parts by #s alot easier, ford had a system that even let you know not only the year but the body + car it would fit
#855872
11/19/10 11:49 AM
11/19/10 11:49 AM
Posts: 543 Indiana, Just Off I-70
BradD
From what I have seen is that a 6 digit # is pre 1950, 7 digit #'s starting with 1 are 1950's, 7 digit #'s starting with 2 are 1960's, 7 digit #'s starting with 3 are 1970's. The second digit is the year in said decade, IE part #1465802 would be for 1954. Part #2768882 would be 1967. 1970 started most part #'s with 34*****. 1971 #'s 35***** and so on. This doesn't hold true for all part #'s, but is a good reference or starting point. Some part #'s were used for many years, mostly hardware items such as the #2467770 Brake pedal bushing still used til recently on PT Cruiser's and some mini van's. Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: gtx6970]
#855874
11/19/10 11:42 PM
11/19/10 11:42 PM
Posts: 21,555 N.E. OHIO, USA
A12
N.E. OHIO, USA
Like Tony said,,,,,there will always be non conforming items to any of the suggested formulas.
example 3454390-391
outer door handles for 1969-70 B-body ( and maybe be 1968 as well, )
Bill, I just looked at the radiator listing and there are a few years that make some sense but for the most part it's totally ballpark yes/maybe, set in stone - NOT. You, Tony and the rest of the guys/gals that have experience and have worked with Mopar parts for all of these years/decades know your stuff and to all of you
To me mopar part numbers are like trying to figure out an area code and where someone might be calling you from, there's no real rhyme or reason to an area code you recognize them from experience and then they go and throw in cell phones that someone can call you from anywhere
MikeR
[Re: JohnRR]
#855876
11/20/10 06:23 PM
11/20/10 06:23 PM
Posts: 4,999 North Pole,New York
formula_s
North Pole,New York
Also need to remember that some parts carried over from previous years so A part that was made for a much earlier car could end being used a decade later and if there was no change to the part it could still carry that much earlier number.
So true, A body upper control arm bushings are 2071204 dating back to the begining.
[Re: gtx6970]
#855877
11/20/10 06:42 PM
11/20/10 06:42 PM
Posts: 17,529 Las Vegas, NV
6bblgt
Las Vegas, NV
example 3454390-391
'68 parts catalog shows:
'68 b-body (2-door) chrome button #2486704/705 (also, all '67 A & '66-'67 C-bodies front and others) black buttons #2862972/973
