What is the biggest overbore a 340 block can take? #855720
11/17/10 12:04 AM
11/17/10 12:04 AM
Round lake, IL
ra340 Offline OP
ra340  Offline OP
Round lake, IL
Has any one sonic checked a stock 340 block to see how big of overbore a 340 can take? I have seen blocks bore .060 over to 4.100 Has anyone gone past this to 4.125?
Re: What is the biggest overbore a 340 block can take? [Re: ra340] #855721
11/17/10 12:12 AM
11/17/10 12:12 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Sonic testing only tells you what that individual block can go out to; if you're planning a max bore you'll need to test the block you have in mind.
Stiffer walls make more power than the last .010 or so you can cut away.
Re: What is the biggest overbore a 340 block can take? [Re: topside] #855722
11/17/10 12:46 AM
11/17/10 12:46 AM
Round lake, IL
ra340 Offline OP
ra340  Offline OP
Round lake, IL
I plan to have any block I overbore past .030 sonic tested.
My question is if going past 4.070 is a good idea. If someone has sonic checked a 340 block I like them to post their findings. We could all use this information as to what is a safe overbore for most 340 blocks.
Re: What is the biggest overbore a 340 block can take? [Re: ra340] #855723
11/17/10 12:55 AM
11/17/10 12:55 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
back then 40 was the most...but with the new r blocks u can go more
Re: What is the biggest overbore a 340 block can take? [Re: AARCONV] #855724
11/17/10 06:02 PM
11/17/10 06:02 PM
Round lake, IL
ra340 Offline OP
ra340  Offline OP
Round lake, IL
Re: What is the biggest overbore a 340 block can take? [Re: ra340] #855725
11/17/10 08:08 PM
11/17/10 08:08 PM
K
kielbasa Offline
kielbasa  Offline
K
as big as the sonic check allows you to........
I just had my 1971 360 block sonic checked for the second time (from a different party than the first time) because the numbers first time around came in a little too good to be true, block was already punched .040 over in a previous rebuild, but thrust surfaces still range from .200 to .350 yet........
