Re: 727 opinions needed!
[Re: PJM]
#855448
11/16/10 07:31 PM
11/16/10 07:31 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Linkage or cable kickdown?
If linkage, does the aftermarket carburetor have the correct Mopar throttle lever extension?
[Re: PJM]
#855452
11/17/10 10:57 AM
11/17/10 10:57 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
Thanks will give it a try
What about this question you failed to answer? What you want to do can still be affected by this.
[Re: PJM]
#855454
11/17/10 05:28 PM
11/17/10 05:28 PM
John_Kunkel
Rio Linda, CA
The Lokar only works properly if the travel of the carburetor lever matches the travel of the transmission lever, they are usually not the same.
Redrilling the hole on the transmission lever will most likely allow you to adjust the light throttle shift points without any governor mods.
[Re: PJM]
#855456
11/17/10 05:53 PM
11/17/10 05:53 PM
JohnRR
Would it not do the same by adjusting some slack in the cable? Right now it moves right when the throttle moves.
No, the Lokar is not setup properly for the application it is sold for.
The cable setup sold by Bouchillon is the better/correct setup to use .
[Re: John_Kunkel]
#855458
11/17/10 06:18 PM
11/17/10 06:18 PM
Posts: 213 florida
PJM
florida
If I understand you correctly it would be like choking up on a bat? Do you know the proper measurements for the travel? Thanks, ![](/ubbthreads/images/graemlins/thumbs.gif)
