How does Easy Off remove anodize on grills ? #855417
11/16/10 05:49 PM
11/16/10 05:49 PM
IL . usa
cjs69mope Offline OP
IL . usa
I think i have heard this before but was wondering if somebody could tell me for sure.
If so how long does it take? Do i spray it on and leave it or what ?
Any advise or tips on this would be appreciated.
Thanks Cj.
1969 Dodge Charger 1969 Dodge Superbee
Re: How does Easy Off remove anodize on grills ? [Re: cjs69mope] #855418
11/16/10 06:44 PM
11/16/10 06:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Easy ... it eats the aluminum away until there's nothing left for the anodizing to stick to. It says right on the can - DON'T USE ON ALUMINUM !!!
Re: How does Easy Off remove anodize on grills ? [Re: Stanton] #855419
11/16/10 07:04 PM
11/16/10 07:04 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Easy off is used to remove oil stains off your exhaust. I would not use it on aluminum. Eastwood I think has what you need.
Caswell also sells a kit to remove and anodize aluminum.
Anodizing at home
Re: How does Easy Off remove anodize on grills ? [Re: cjs69mope] #855420
11/16/10 09:37 PM
11/16/10 09:37 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I stripped the annodizing on a number of parts and then buffed a shine back into them after straightening. Go buy a can of Drano kitchen crystals. Dissolve some with hot water in a container large enough to hold your part. Drop the part in. It will start bubbling like a soda pretty quickly. Within 20 minutes your part will have a gray coating of smut. Take it out and rinse/rub thoroughly. No more annodizing.
It's the Sodium Hydroxide (lye) that does the work. Same ingredient in oven cleaner. Trust me, your part won't disappear in the solution and it only takes a few minutes.
Pics here: http://70duster440.com/grilleresto.html
Oven cleaner WILL discolor cast aluminum (like a transmission case). The warnings on the can are more about discoloration than destroying the part. Turns dark gray.
Oh, and don't forget rubber gloves and face protection as a safety precaution.
Re: How does Easy Off remove anodize on grills ? [Re: 70Duster440] #855421
11/16/10 10:40 PM
11/16/10 10:40 PM
pennsylvania
hotrodram Offline
hotrodram  Offline
pennsylvania
i used the easy off on my 68 dart grille. sprayed it on, waited 10-20 min,used old toothbrush to scrub old anodize off, wash with water....polished and looks great! to keep polished, went with SEM clear coat out of spray can(autobody store),,SEM will not yellow like some clear coats
Re: How does Easy Off remove anodize on grills ? [Re: 70Duster440] #855422
11/16/10 10:43 PM
11/16/10 10:43 PM
pennsylvania
hotrodram Offline
hotrodram  Offline
pennsylvania
heres a pic of my 68 dart grille. used easy off,toothbrush to scrub, water to wash down and 3 days of polishing
Re: How does Easy Off remove anodize on grills ? [Re: hotrodram] #855423
11/16/10 11:11 PM
11/16/10 11:11 PM
IL . usa
IL . usa
thanks for all the replies going to go to the grocery store now to buy some .
Re: How does Easy Off remove anodize on grills ? [Re: cjs69mope] #855424
11/16/10 11:36 PM
11/16/10 11:36 PM
The Lye in Easy Off is what removes the anodizing.
It took three applications on my '63 Dodge grille and sitting in the sun for it to all come off.
Don't get the "fume free" it's crap!
After many hours of wet sanding, straightening and polishing:
Re: How does Easy Off remove anodize on grills ? #855425
11/17/10 12:46 AM
11/17/10 12:46 AM
Oakbank, Manitoba, Canada
64 Savoy Offline
64 Savoy  Offline
How did you guys do the "black out" detailing? Hope I didn't hijack?
64Savoy
Re: How does Easy Off remove anodize on grills ? [Re: 64 Savoy] #855426
11/17/10 05:07 AM
11/17/10 05:07 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i've done grills and trim with EZ Off as well. you need the "heavy duty" formula, not the fume free one. leave it of for 20-30 minutes, scrub with a green 3M pad, rinse well, and see what you have. you might have to redo sections, with tougher clear on it, but it works. polish when you're done, and clear coat it again, or it will get dull pretty quick. after polishing, but before clear coating, i've done the black, by masking the grill with "photo frisket" and using an exacto knife to cut out the stripes and letters, then hitting with satin black paint. just make sure the black is compatible with the clear coat you chose.
Re: How does Easy Off remove anodize on grills ? [Re: Golden-Arm] #855427
11/17/10 10:17 AM
11/17/10 10:17 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Do this outside!!! the gas that is given off is pure Hydrogen. last thing you want to do is build up hydrogen in your garage.
**Photobucket sucks**
Re: How does Easy Off remove anodize on grills ? [Re: 64 Savoy] #855428
11/17/10 06:14 PM
11/17/10 06:14 PM
64Savoy
Very carefully!
Green masking tape and brand new x-acto knife blades and lots of patience!
Don't cut into the aluminum but just deep enough to get through the tape.
I sprayed some paint in a cup and used a modeling brush to do the tiny areas that only required a drop or two of paint in between the center grille bars.
Re: How does Easy Off remove anodize on grills ? #855429
11/17/10 06:31 PM
11/17/10 06:31 PM
Here's another example of what you can do with masking and an X-acto knife.
The air cleaner was chrome but getting ugly looking.
I masked off the Edelbrock and blasted it with black wrinkle finish.
I'm pretty much to the point that I hate anything chrome in the engine compartment but I thought this turned out decent.
Re: How does Easy Off remove anodize on grills ? [Re: Golden-Arm] #855430
11/18/10 01:35 AM
11/18/10 01:35 AM
64 Savoy Offline
64 Savoy  Offline
Great work guys!! Any recommendation on the brand of satin black paint?
What is "photo frisket" and why did you use it instead of masking tape?
Thanks,
Finally getting to mine on the 64.
Re: How does Easy Off remove anodize on grills ? [Re: 64 Savoy] #855431
11/18/10 03:43 AM
11/18/10 03:43 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
photo frisket is like clear masking tape, but it comes in sheets. for covering a larger area, then trimming away what you dont need. i also use blue painters tape, and visqueen if i dont have the frisket. i like the frisket, because it's transparent, so you can easily see what you are trimming against, and if there's an air bubble, it's also quite visible. the paints you choose, should be compatible. if you use SEM trim black, use SEM clear, etc. just depends if you are going to use an airbrush, rattle cans or spray gun, and what you're comfortable shooting. i like SEM or PPG, but really anything you are happy with, is best. as mentioned above, i also will use a small detail brush, for getting into tight spots, or detailing emblems, etc.
Re: How does Easy Off remove anodize on grills ? [Re: Golden-Arm] #855432
11/19/10 01:23 AM
11/19/10 01:23 AM
64 Savoy Offline
64 Savoy  Offline
Thanks. Now to find this stuff!!
Re: How does Easy Off remove anodize on grills ? [Re: 64 Savoy] #855433
11/19/10 10:02 AM
11/19/10 10:02 AM
London, England
Gavin Offline
Gavin  Offline
London, England
BTW, my local plating guys (who also do bright dip anodising) quoted me about $70 to strip and reanodise my 71 Challenger headlight bezels, with me taking the parts away to fix inbetween.
They stripped them right there on the spot, literally took about 5 mins, and didn't charge me anything on the spot.
So, my point is that it may cost you hardly anything to get them stripped, and it sure is quick and mess free.....just a thought.
Re: How does Easy Off remove anodize on grills ? [Re: 64 Savoy] #855434
11/19/10 11:10 AM
11/19/10 11:10 AM
33950
67Monaco Offline
67Monaco  Offline
33950
Easy as pie..
http://www.dickblick.com/products/badger...mckw=25203-1901
Re: How does Easy Off remove anodize on grills ? [Re: 67Monaco] #855435
11/19/10 12:23 PM
11/19/10 12:23 PM
scratchnfotraction Offline
I used the aircraft paint remover on my 68 dart front grill
removed the silver argent paint/black out paint in a couple mins and rinsed with water
never had to buff/shine it,it was super shiny when done
but that may not be the same as anodized alum
worked great on the grill though
just thought i would throw it out there
Re: How does Easy Off remove anodize on grills ? [Re: 70Duster440] #855436
11/20/10 08:33 AM
11/20/10 08:33 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I made a trough by taking a length of 3" PVC pipe and cutting an opening along the length of it. Glued a cap on each end and used it to put my '65 coronet fender, door, and quarter panel mouldings into a solution of drano and hot water. Worked well and fast. Removing the anodizing is easy, the hard part is buffing and polishing.
This is the land of the free because of the brave
