Anti-Seize necessary for Alum. Bell housing bolts?
#855249
11/16/10 02:19 PM
11/16/10 02:19 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Getting ready to bolt my manual trans to the bell housing but wasn't sure if I needed anti-seize for the bolts since the bellhousing is aluminum. I would think I do but when I checked the service manual it says nothing about it. Just says bolt it up. Joe
65 Barracuda 70 Challenger
Re: Anti-Seize necessary for Alum. Bell housing bolts?
[Re: jrwoodjoe]
#855250
11/16/10 02:30 PM
11/16/10 02:30 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I use it any time I'm putting steel bolts into an aluminum casting.
[Re: AndyF]
#855255
11/17/10 12:44 AM
11/17/10 12:44 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
To be honest, I get a set of dog pointed studs and use them instead of bolts, with anti seize.
[Re: Supercuda]
#855256
11/17/10 10:06 AM
11/17/10 10:06 AM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
Kevin I agree.I use it on everything.Last 2 shops I worked at I even got the guys there to use it all the time.I told them if it comes back in say 2 years for the same repair it will come apart easy.In Ohio the rust is bad.Only time I dont use it is when lock tite or teflon is used.I even take brake bleeders out all the way and use a dab on them.Rocky
Chrysler Firepower
[Re: therocks]
#855257
11/17/10 10:59 AM
11/17/10 10:59 AM
Posts: 75,135 A Banana Republic near you.
JohnRR
I do the same thing . I also slathered it all over the front bearing assemblies on my 2000 2500 Ram so I don't have to the ball joints the next time I have to replace one .
