Engine Location/ shims #855185
11/16/10 12:55 PM
11/16/10 12:55 PM
California
P
Plymouth273 Offline OP
P
California
Installing Headers and need to shift my engine about 5/16" towards the driver side. The car is a 65 Polara (C-Body), It has new motor mounts from Schumacher and a new transmission mount also. Can I just put a 5/16" shim between the motor mount bracket and the K-Member mount, then lower the engine, or is there a better way of doing it?
Thanks.
Re: Engine Location/ shims [Re: Plymouth273] #855186
11/16/10 01:21 PM
11/16/10 01:21 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
In the past, have loosened motor and trans mounts and tugged the motor in the direction I wanted, then tightened everything back up. It worked for me.
Re: Engine Location/ shims [Re: Plymouth273] #855187
11/16/10 03:39 PM
11/16/10 03:39 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I shimmed the one side in my 65 B body.It has all new poly mounts and the right side was too close to the inner fender.Its been like that for 3 years and no problems.Rocky
Chrysler Firepower
