Edelbrock carbs on street hemi intake manifold? #855181
11/16/10 12:50 PM
11/16/10 12:50 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Will edelbrock carburetors mount on a stock street hemi intake manifold? Can I use the stock fuel line and linkage? Thank you for any help.
Re: Edelbrock carbs on street hemi intake manifold? [Re: sbcjd] #855182
11/16/10 12:58 PM
11/16/10 12:58 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yes they will fit on the manifold but the stock air cleaner will not because the air horns are bigger, the stock linkage might with some mickey mousing as the crank arms on the carb are different, the fuel lines will once you add on the correct fittings.
Contact Scott Smith for more info and possibly some clone carbs .
Re: Edelbrock carbs on street hemi intake manifold? [Re: JohnRR] #855183
11/16/10 02:44 PM
11/16/10 02:44 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Thank you for your reply.
