bodymen, panel warpage... what to do? #85462
07/07/08 08:27 PM
07/07/08 08:27 PM
right between milan dragway & ...
Flite_727 Offline OP
well i did it good this time! i warped the heck outta my door while welding in a donor plug to fill the recess around the door handle.(cloning an earlier model) the low spot is "oil canned" it will pop out with pressure from behind, but will pop back when pressure is released. if i understand my research correctly, the steel around the weld has shrunk causing the warping & needs to be streched out to releive the stress. what is the best way to do this???? secondly, how do i prevent this from happining again on the other side, i did the skip around tack weld method, like i always have but this still happened.
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: bodymen, panel warpage... what to do? [Re: Flite_727] #85463
07/07/08 08:28 PM
07/07/08 08:28 PM
here is a straight edge held up to the low spot.
Re: bodymen, panel warpage... what to do? [Re: Flite_727] #85464
07/07/08 09:01 PM
07/07/08 09:01 PM
Williamsport, PA
Kingy Offline
Royal Pain
Kingy  Offline
Royal Pain
Williamsport, PA
Unfortunately the recess will need to be shrinked, shrank, shrunk to eliminate the oil canning.
Re: bodymen, panel warpage... what to do? [Re: Kingy] #85465
07/07/08 10:25 PM
07/07/08 10:25 PM
Iowa
3
318Bruiser Offline
318Bruiser  Offline
Iowa
My father used to heat up the recessed spot and then use a sponge with water right above it and have the water rush down to the hot spot. Worked sometimes but he was the body man and I am not. Hope that helps some.
Re: bodymen, panel warpage... what to do? [Re: Flite_727] #85466
07/08/08 12:13 AM
07/08/08 12:13 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
I'm not a bodyman, but I think they sell shrinking hammers. If I recall correctly, you have to hammer and dolly the area in a concentric circle to move the metal back toward the center.
Re: bodymen, panel warpage... what to do? [Re: moparmojo] #85467
07/08/08 12:25 AM
07/08/08 12:25 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
To prevent future problems you can use the heat absorbant playdoh that Eastwood sells or you can tack weld a heavy steel angle iron to the area before you start work and leave it on until it cools.
To fix the already warped panel you can try the heat and chill method mentioned or worst case you can take a die grinder and cut a slit in the warp, tack weld an angle to it to hold it flush and weld up the slit, slowly.. watch the heat when grinding the weld down also..
Re: bodymen, panel warpage... what to do? [Re: sthemi] #85468
07/08/08 12:30 AM
07/08/08 12:30 AM
cut a slit in it?!? i would push it back out till it stays, then work it with a body hammer and dolly.
use minimal bondo to clean up the ruff spots.
Re: bodymen, panel warpage... what to do? [Re: Flite_727] #85469
07/08/08 01:06 AM
07/08/08 01:06 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
to do it right reheat with bottle torch then dolly it back to substraight with shrinking hammer, then matel file with vixin file to see how close you are
MOPAR OR NO CAR
Re: bodymen, panel warpage... what to do? [Re: hemigod426] #85470
07/08/08 01:12 AM
07/08/08 01:12 AM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
Buy a shrinking disc... Eastwood sells 'em: Shrinking Disc
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: bodymen, panel warpage... what to do? [Re: Flite_727] #85471
07/08/08 09:49 AM
07/08/08 09:49 AM
Tulsa, OK
73cudaproject Offline
Tulsa, OK
While welding in an upper rear qtr patch panel I experienced the oil can warp. I was using a copper bar but obviously I welded just a touch to long. I tried a veritical cut to relief the metal but ended up cutting the horizontal weld, pushed it back into alignment, re-welded and I beleive it turned out just fine. I did not have a shrinking hammer. In your case I like the idea of heating and shrinking with a wet rag. Good Luck!
Re: bodymen, panel warpage... what to do? [Re: 73cudaproject] #85472
07/08/08 10:42 AM
07/08/08 10:42 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
what happened was when you welded it expanded the metal causing a high spot and the panel formed a oil can.
now to fix it properly with a heat shrink.
you need to hit the oil can area UP and then find the highest point in the panel. a lot of times it will not be in the oil can area.
heat this spot up with a torch until it's cherry red, note don't heat up a area any bigger that the size of hammer head, i my myself stick with about 1/2".
now hold a flat dolly behind the heated area. strike the panel around the flat spot with the force of the blows towards the red spot. hit it about 6 times around the circumference of the spot. then strike the heated spot directly forcing the metal you moved towards the heated spot to to shrink.
now cool the heated spot and the oil can should be gone.
you just did a heat shrink.
if not find the next highest spot and repeat the above steps.
the most important thing to remember is heat shrink the high spot of the metal. a lot of times it won't even be in the oil can area it will be next to it.
i myself don't like shrinking hammers and things like that. if used improperly they can make more problems than what you had.
perception is 90% of reality
Re: bodymen, panel warpage... what to do? [Re: Mr T2U] #85473
07/08/08 11:43 AM
07/08/08 11:43 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Hope you don't mind if I jump in here. I've got a similar problem with my trunk lid from a different cause. I sandblasted the back side of my 'Cuda trunk lid thinking since there's an inner panel it wouldn't harm the outer sheet metal. The back side looks great, but now there's an "oil can" area on the outside skin that wasn't blasted.....how do I fix that?
Re: bodymen, panel warpage... what to do? [Re: 6pkaar] #85474
07/08/08 12:05 PM
07/08/08 12:05 PM
Canada
RobR Offline
RobR  Offline
Canada
Oh Man I don't know how many times I've come across bad B body trunk lids with that problem.
MrT2U has the only way to fix that problem...it does take a while but it is the Quickest and safest way for that type of repair.
That is a bad one you have there !!don't envy you at all...
Re: bodymen, panel warpage... what to do? [Re: RobR] #85475
07/09/08 09:26 PM
07/09/08 09:26 PM
anybody have any experience w/ a shrinking disc??? seems like the most foolproof way to handle this if they work as advertised.
Re: bodymen, panel warpage... what to do? [Re: Flite_727] #85476
07/09/08 09:50 PM
07/09/08 09:50 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
A shrinking disk is a way to apply and generate heat in a controlled area. It takes practice and works in all areas, even if there is support structure in the back. E-bay has then also. I like the larger diameter disk that fit on a larger heavy-duty variable speed buffer/grinder.
Re: bodymen, panel warpage... what to do? [Re: convx4] #85477
07/09/08 10:58 PM
07/09/08 10:58 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
I soak/stir torn newspapers in a 1/2 bucket of water till they fall apart. Then squeeze a handfull of paper paste and make/stick a thick border dam on both sides of where your welding/brazing sheet metal. A real old bodyman showed me this tip for warpage in the 60s when we brazed everything for body panels.
Re: bodymen, panel warpage... what to do? [Re: Mr T2U] #85478
07/13/08 12:10 PM
07/13/08 12:10 PM
Tulsa, OK
Tulsa, OK
With hindsight I believe MrT2U's method would have been the best solution for my oil can situation. Since I ended up making the horizontal and then re-cutting the vertical seam I am very thankful I had the butt weld type panel clamps...
