Indy 440-1 users come on in!
#854622
11/15/10 06:07 PM
11/15/10 06:07 PM
Posts: 6,295 U.S.
moparniac
U.S.
My block is finally back from the machine shop so its time to "cam up" So all the dash one users on here if ya dont mind please post up your cam specs/compressions/power/et etc... gonna be ordering a came here in the next couple weeks so need idears!
Mopar Performance
Re: Indy 440-1 users come on in!
[Re: moparniac]
#854623
11/15/10 06:11 PM
11/15/10 06:11 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Talk to Dwayne, that's the only idea you need.
[Re: Bigcube]
#854627
11/15/10 06:17 PM
11/15/10 06:17 PM
Posts: 6,295 U.S.
moparniac
U.S.
my old cam was a bullet 269/269 .430/.430 on a 110
Ive read from several people on here that the dash ones love a split duration!
Mopar Performance
[Re: moparniac]
#854628
11/15/10 06:42 PM
11/15/10 06:42 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
No Voodoo in cam design. No mystery to unlock, no hidden power to be had. Dont expect much, it just wont happen. Unless the old cam is way off in duration or what the engine wants...it just wont happen. No magic duration to unlock hidden power. I also suggest in getting the cam from Porter However, he will make sure the cam is correct in application....A fail-safe if you will.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#854629
11/15/10 06:45 PM
11/15/10 06:45 PM
Posts: 6,295 U.S.
moparniac
U.S.
old cam is trashed and need a new one regardless. thx
Mopar Performance
[Re: moparniac]
#854635
11/15/10 08:52 PM
11/15/10 08:52 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
268-272 max on then intake duration. That 269/269/110 that you mentioned is probably pretty close.
8.30's @3400 lbs
[Re: Mike Swann]
#854637
11/15/10 09:02 PM
11/15/10 09:02 PM
Posts: 6,295 U.S.
moparniac
U.S.
My dash ones are the cnc 345s 2.25/1.81
Mopar Performance
[Re: moparniac]
#854638
11/15/10 09:42 PM
11/15/10 09:42 PM
Posts: 3,458 Dandridge TN
Dabee
Dandridge TN
Here is mine.
CNC ported heads jesel rockers and belt drive 1.7 rockers 12.5 comp 496 ci bill miller pistons eagle crank, Alum rods
Engine is in a 225 RED
Dyno 817 hp @ 7200 RPM 660 TQ @ 5500
[Re: moparniac]
#854639
11/15/10 09:49 PM
11/15/10 09:49 PM
Posts: 16,929 NC
440Jim
NC
You really should post your combo, because the cam is very dependant on the rest of the parts, CID, CR, stall speed, gear, tire dia, weight, etc. etc.
I am running a flat tappet (solid) at 13.5 CR in a 511 CID:
305º/320º@.020", 279º/287º@.050", 197º/200º@.200", 143º/143º@.300", 112º/107º@.350", 0.433"/0.420" lobe lift, 110 LSA
[Re: Dabee]
#854640
11/15/10 09:56 PM
11/15/10 09:56 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
275@50 ,, 585/w 1.5s I've got 1.6s on the intakes.... And my lifters don't roll, they turn. Its a 383 though. 620 or so?
[Re: RemCharger]
#854641
11/16/10 12:19 AM
11/16/10 12:19 AM
Posts: 644 Minnesota
Barnstorm
Minnesota
2.25 intakes..1999yr good Knowlton port 385/295 flow..2in hookers..1150 dom on indy manifold..cam 294-288ex...741/693lift..500in 4.38x4.15..820hp..712tq
The little old lady from Pasadena is back!
