Re: Throttle cable to short... What do yall use? [Re: tboomer] #853683
11/15/10 11:26 AM
11/15/10 11:26 AM
GA
Boosted Offline OP
Boosted  Offline OP
GA
My car was a factory small block with a 4 speed so i am assuming the cable in it is the original one. The car was owned by my friend for 36 years before I got it and it was never changed.
I will look at the firewall and see what type hole it has when i get home..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Throttle cable to short... What do yall use? [Re: Boosted] #853684
11/15/10 11:33 AM
11/15/10 11:33 AM
an8sec70cuda Offline
I use a Lokar cable, but I did the same thing Al does and got a new thicker cable from the hardware store. No problems.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Throttle cable to short... What do yall use? [Re: tboomer] #853685
11/15/10 11:44 AM
11/15/10 11:44 AM
Ransom Canyon, Texas
Madness Offline
Madness  Offline
TBoomer, www.partsamerica.com not available? How long ago did you visit them?
Re: Throttle cable to short... What do yall use? [Re: Madness] #853686
11/15/10 11:47 AM
11/15/10 11:47 AM
tboomer Online work
tboomer  Online Work
I ordered the cable from my local Carquest...He is a racer and usually can match some of the big names in prices...
Re: Throttle cable to short... What do yall use? [Re: Boosted] #853687
11/15/10 12:01 PM
11/15/10 12:01 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
As far as using a thicker cable, I've used the cable I get for garage door lock's. Thicker, still stainless strand, and fits inside the cable housing. If you need some, send me your addy and the length.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Throttle cable to short... What do yall use? [Re: Boosted] #853688
11/15/10 12:58 PM
11/15/10 12:58 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
I used a bicycle cable. I made an adapter bushing for the stock pedal assembly out of aluminum (on the lathe), made a clamp bushing out of Al like stock , took a piece of mild steel cut to length, drilled and taped it to fit a small rod end. I swaged it in a small hydralic press.
