flaming river install #853243
11/14/10 09:41 AM
11/14/10 09:41 AM
lancaster pa
N
nitrohemi Offline OP
N
lancaster pa
will the mopar flaming river universial fit on my chrysler 5th ave steering box? if I recall most all the mopar steerign boxes are the same spline and flaming river only sells one universial for mopar boxes. don't want to drop that much money and then not fit
31 dodge 3 window coupe 67 hemi gtx 2000 prowler 1949 dodge shop truck
Re: flaming river install [Re: nitrohemi] #853244
11/14/10 01:20 PM
11/14/10 01:20 PM
Outside
thedriver Offline
thedriver  Offline
Outside
flaming river box takes the different splined pitman arm. same one the pre 70 b bodies had i thinks. been a while since i did the swap.
1973 challenger
Dana. 4 speed. Low deck.
Re: flaming river install [Re: thedriver] #853245
11/14/10 02:09 PM
11/14/10 02:09 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
On my 72 'Cuda the flaming river was a drop in, pitman arm and all. I went with their coupler which meant I had to shorten my steering shaft about an inch. No big deal but it sure took the slop outta it, better than the rubber isolator mopar used.
