Page 1 of 3 1 2 3
1971 R/T 440 6 Pack Survivor #852745
11/13/10 08:36 PM
11/13/10 08:36 PM
United States
boatmangc Offline OP
United States
I am new to this forum, I was referred by a friend of mine on another forum.
I have owned many Mopars through the years my best being a 69 RR 383 4 speed Texas car with 42K on the clock.
I have just been given the privilege of Bringing this beauty back to life.
It is an original paint, interior car with 80,000 miles on it. It has hideaway lights and a console mount cassette deck with a microphone.
I spoke with Galen Govier about the car, gave him the numbers off of the trans, rear and block. Unfortunately I did not find the serial number from the block but the casting number and build date. Galen says the numbers I have given him so far appear to be correct.
I have the build sheet, owners manual, shop manuals and dealer brochures as well as period correct Hot Rod, Car Craft and other magazines.
It is a garage kept Arizona car for the last 20 years, the owner got sick and passed in the last 3 years and the car has been sitting for the last 2 years, it was driven to his funeral and evidently it backfired all the way because the mufflers are ballooned.
I flew to Az a few weeks ago and pushed it out of the garage to see what I was up against. I pumped the fuel tank dry, changed the oil checked the coolant, got 5 galllons of hi test added, lead substitute, octane boost and Seafoam and proceed to get her lit up.
Got it started after a bit but only on the primary carb, let id idle while watching temp, oil pressure etc. The motor sounds real healthy other than needing a good carb job, I had to replace a few plug wires but that is it.
I let it idle for about 20 minutes and dumped the oil again, this time I added a little Marvel Mystery oil to it as well (I figured it wouldn't hurt a bit).
I have never had the pleasure of playing with an Az car before but the stories you hear are not a myth. I can't believe the absolute lack of rust! The sail panel, the quarters, the floor pans.
The only rust I have found on the car is under the trunk mat but it is not perforated.
I will be looking for a few parts for it but mainly advice.
At this point The part I will need soonest is the right side valve cover it is somehow bent around the filler cap.
I look forward to meeting people on this forum and most likely will post a few noob questions until I get used to the format of this forum.
Here are a few pictures, Enjoy!!
O bsessive C ar D etailer
Re: 1971 R/T 440 6 Pack Survivor [Re: boatmangc] #852746
11/13/10 08:42 PM
11/13/10 08:42 PM
Chilly Northern, Minn.
71 Charger R/T Offline
Welcome! WOW! VERY NICE! How is it opted? can you give us a shot of the fender tag? That is one beautiful survivor!
Re: 1971 R/T 440 6 Pack Survivor [Re: 71 Charger R/T] #852747
11/13/10 08:55 PM
11/13/10 08:55 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I'm in love with it
Re: 1971 R/T 440 6 Pack Survivor [Re: 71 Charger R/T] #852748
11/13/10 09:11 PM
11/13/10 09:11 PM
United States
United States
Here ya go!
Anybody with the secret decoder ring can fill me in without offending me.
Re: 1971 R/T 440 6 Pack Survivor [Re: boatmangc] #852749
11/13/10 09:18 PM
11/13/10 09:18 PM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
Way Cool! Welcome to the board!
KID
Re: 1971 R/T 440 6 Pack Survivor [Re: boatmangc] #852750
11/13/10 11:09 PM
11/13/10 11:09 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I like it!
I've got a V code '71 Challenger, same color.
Re: 1971 R/T 440 6 Pack Survivor [Re: Mastershake340] #852751
11/14/10 11:42 PM
11/14/10 11:42 PM
IL
71383beep Offline
71383beep  Offline
IL
Sweet!
'73 GK6 Challenger Rallye - 340 4-Speed
Re: 1971 R/T 440 6 Pack Survivor [Re: 71383beep] #852752
11/15/10 03:40 PM
11/15/10 03:40 PM
Paducah, KY
bigsexy440 Offline
bigsexy440  Offline
Paducah, KY
So so so so so jealous of you...
Re: 1971 R/T 440 6 Pack Survivor [Re: bigsexy440] #852753
11/15/10 07:49 PM
11/15/10 07:49 PM
indiana
generallee6901 Offline
indiana
Very nice.
Re: 1971 R/T 440 6 Pack Survivor [Re: boatmangc] #852754
11/15/10 08:04 PM
11/15/10 08:04 PM
MD
floyd Offline
floyd  Offline
MD
Check out those 450 steelies! Awesome car.
Re: 1971 R/T 440 6 Pack Survivor [Re: floyd] #852755
11/15/10 08:10 PM
11/15/10 08:10 PM
MI
68shifter Offline
68shifter  Offline
MI
Thats just cool
Especially the steel wheels and sleeper look.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: 1971 R/T 440 6 Pack Survivor [Re: boatmangc] #852756
11/16/10 07:30 PM
11/16/10 07:30 PM
Here ya go!
WS23=DODGE CHARGER TWO DOOR R/T
V=440 3-2 BBL HP
1=1971
A=LYNCH ROAD PLANT
E87=440 6BBL MOTOR
D32=3 SPEED AUTOMATIC 727
GK6=DARK BRONZE METALLIC PAINT
D6T7=TRIM GRADE DELUXE,VINYL BUCKET SEATS,COLOR CHESTNUT
GT8=UPPER DOOR FRAME DARK TAN
429=SCHED.PROD.DATE, APRIL 29 1971
GK6=DK BRONZE MET. ROOF
U=BUILD TO U.S. SPECS
V68=LONGITUDINAL TAPE SPORT STRIPE-DELETE
C16=CONSOLE WITH WOOD GRAIN
26=26" RADIATOR
L37=CONCEALED HEADLAMPS
G11=TINTED GLASS
413=440 6BBL
046=3.55 8.75" SURE GRIP REAR AXLE FRONT AND REAR DRUM BRAKES
Your car is soooo cool!!!
can we see some pictures of the interior?
Windows, tach, AM/FM cassette?
My car's SPD is exactly 3 months before yours.
Re: 1971 R/T 440 6 Pack Survivor [Re: boatmangc] #852757
11/17/10 12:07 AM
11/17/10 12:07 AM
Cleveland, Ohio
71VBEE Offline
71VBEE  Offline
Cleveland, Ohio
Boatmangc;
Great to see (very close to) original cars that pop up 35+ years later. I would like to see close up/detail pics of the throttle linkage/kickdown rod set up on the six pack set up if you can, it would be greatly appreciated. Thanks,
Steve
1971 Superbee 440-6 automatic being restored.
1971 Superbee 440-6 auto dana airgrabber
The resto started: Nov 2004, now its 2024 and its 95% finished. I can't believe it is the same car I started with.
1964 Corvette coupe...always gets more attention than the Bee from the general public.
Re: 1971 R/T 440 6 Pack Survivor [Re: 71VBEE] #852758
11/17/10 10:49 AM
11/17/10 10:49 AM
United States
United States
I'm not sure I made this clear, the car doesn't belong to me. Unfortunately
It belonged to my accountant's late brother. He had a "friend" who told her the car was only worth 13-18K and he would take it off of her hands.
Fortunately she knew I was a gearhead and asked me about it. As soon as I heard 6 pack and original paint I knew it was special.
I will be making this car 100% correct and assisting her with the sale. I don't think it needs much to be 100%.
I will have GTS do a complete registry/survey on the car before offering it for sale.
I am absolutely in love with this car but I realize it is out of my reach at this time.
Now if it were a 68-69 RR/GTX vert, I would finance everything I have for it.
71VBEE
I think I might already have a picture of the linkage, if not I will get you a shot, anything I can do to help out anyone with reference just let me know.
Re: 1971 R/T 440 6 Pack Survivor [Re: boatmangc] #852759
11/17/10 04:49 PM
11/17/10 04:49 PM
Paducah, KY
bigsexy440 Offline
bigsexy440  Offline
Paducah, KY
I dont think you should touch it personally... one persons idea of 100% and anothers are well just that... ideas...
Re: 1971 R/T 440 6 Pack Survivor [Re: bigsexy440] #852760
11/17/10 05:47 PM
11/17/10 05:47 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
GG white book...1 of 98
Semper Fi
Re: 1971 R/T 440 6 Pack Survivor [Re: bigsexy440] #852761
11/18/10 09:31 AM
11/18/10 09:31 AM
United States
United States
Only going to install the correct orange air cleaner cover, (has chrome), I have the correct one.
Radiator hoses are NAPA not Mopar
Fuel filter is some blur/red billet menagerie.
A couple of incorrect hose clamps
wire Scotchlocked in by ballast resistor.
That is about all.
and a battery
Re: 1971 R/T 440 6 Pack Survivor [Re: GOLDMYN] #852762
11/18/10 09:34 AM
11/18/10 09:34 AM
United States
United States
Talked to GG, If all numbers match, 1 of 38 counting this one in the US, 1 of 44 worldwide in registry.
Only one GG knows of with original paint.
I hope to have the GTS registration and appraisal before I have the car shipped.
Re: 1971 R/T 440 6 Pack Survivor [Re: boatmangc] #852763
11/18/10 01:20 PM
11/18/10 01:20 PM
midwest
68427vette Offline
68427vette  Offline
midwest
are you taking offers or listing it at an auction,, if she can sit on it for a few years,, she'll do better, you should buy it!! ,,
Re: 1971 R/T 440 6 Pack Survivor [Re: 68427vette] #852764
11/18/10 03:15 PM
11/18/10 03:15 PM
san diego
JonsGottaDusta Offline
san diego
Wow, that car is awesome!
Page 1 of 3 1 2 3
