Yep, it's possible as I did the same thing. My RR originally had a 2 speed but I wanted a 3 speed to run the N96 air cleaner stuff. I found a decent working 3 speed motor and wired it up. IIRC, I didnt have to wire anything differently in the harness itself. I believe it was pretty much "plug and play." I believe that the is a linkage arm that is different however, which needs to be used with the 3 speed. The 2 speed will work, but I had erratic issues when I had the 2 speed switch. Once I switched over to a good 3 speed switch, things work as they should.
![](/ubbthreads/images/graemlins/beer.gif)
